[Qgis-user] Label with HTML-expressions
Nathan Woodrow madmanwoo at gmail.com
Tue Mar 26 06:22:52 PDT 2013
Lene,
HTML maps labels are not supported....yet. The example label is rendering
the link because QLabels support HTML, which is used to preview the label
result.
What would be you use case for having clickable labels in the map window?
An interactive map?  I'm not sure MapInfo could do this.
- Nathan
On Tue, Mar 26, 2013 at 11:18 PM, Lene Fischer <lfi at life.ku.dk> wrote:
>  Hi Nathan and Andreas
> No it is not in the composer - even though it would be nice if the labels
> in the canvas AND in the printcomposer could be a link.
>  I´v e also tried the MapTip - with same result. I think it must be a
> "bug" because the example in the label shows the element as a normal link.
> It would be nice if it was there. Just as in MapInfo....
>  Regards
> Lene
> ________________________________________
> *Fra:* Nathan Woodrow [madmanwoo at gmail.com]
> *Sendt:* 26. marts 2013 14:14
> *Til:* Lene Fischer
> *Cc:* qgis-user
> *Emne:* Re: [Qgis-user] Label with HTML-expressions
>   Lene,
>  Are you talking about HTML map labels or HTML composer labels?
>  - Nathan
> On Tue, Mar 26, 2013 at 5:49 PM, Lene Fischer <lfi at life.ku.dk> wrote:
>>  I´ve tried to insert a HTML <a href> in the label-expression.
>> The url in coloumn 'www'
>> '<a href="[% "www" %]" target="_blank">link</a>'
>>  The output example looks like a link (blue and underline), but when I
>> look at the map - it is filled with  non interpreted text.
>>  Is there a "render as HTML" label option I have overlooked?
>>  Regards
>>  Lene Fischer
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130326/856fbfa7/attachment.html>
