[Qgis-user] QGIS-master - Printing above A2 shrinks map contents in output
Alexandre Neto senhor.neto at gmail.com
Thu Mar 28 09:04:40 PDT 2013
Using QGIS-master (4189f45) in windows 7 64 bit, Printing a very simple
layout (only vector layers) in any format above A2 gives a correct size
output, but all map contents (including legend) reduced to a size near A2.
In QGIS 1.8, instead of resizing the map contents, part is trimmed on the
right size of the paper.
Using save as PDF the problem does not occur in neither of the versions.
Here some example files:
http://dl.dropbox.com/u/110618644/qgis_print/A1_qgis1.8.print_to_pdf.pdf
http://dl.dropbox.com/u/110618644/qgis_print/A1_qgis1.9.print_to_pdf.pdf
http://dl.dropbox.com/u/110618644/qgis_print/A1_qgis1.9.save_as_pdf.pdf
I don't think it's related to any other ticket (memory related)
http://hub.qgis.org/issues/4821
http://hub.qgis.org/issues/6498
http://hub.qgis.org/issues/5840
http://hub.qgis.org/issues/3687
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130328/b986fcc1/attachment.html>
