[Qgis-user] Running v.clean on a QGIS vector layer (Polygon) through Sextante
Paolo Cavallini cavallini at faunalia.it
Wed May 1 01:32:30 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 30/04/2013 22:41, SBL ha scritto:
> The one is, that if you for example run v.clean through Sextante on a
> polygon layer containing polygons with overlapping areas, the overlapp
> errors are (silently) cleaned during import and therefore not written to the
> final error-output-layer in v.clean...
Same for v.in.* : overlapped areas are level2 polygons in grass, removed during export.
> The other is, that one single tool of v.clean often (usually?) is not enough
> to really clean topological errors (in polygon layers) sufficiant. So,
> beeing able to run a squence of v.clean-tools (like in GRASS) would be a
> performance improvement for advanced topology cleaning I suppose, especially
> when working with bigger datasets...
Trivial to do: just chain several v.clena modules in a sextante model.
All the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.12 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAlGA0x4ACgkQ/NedwLUzIr62iwCfUbieyf1N0DEe3gnJ39aOzgHc
OrwAoJ7dpkDXbA4VMuWyTfi+YviMJUFf
=5Po5
-----END PGP SIGNATURE-----
