[Qgis-user] plugin for processing multiple raster files
Leo Kris Palao
lk.palao at gmail.com
Thu May 2 14:45:17 PDT 2013
Thank you Etienne for your help, I'll try your suggestion. BTW, my data is
in netcdf format. I am having trouble reclassifying my data using raster
calculator when using hdf. I'll email you if I get stuck with the
processing =)
-Leo
On Thu, May 2, 2013 at 7:44 PM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
> Hi,
> I am not sure you need GIS tools (such as QGIS) to do this kind of thing,
> which is fairly routin in the meteorological/climate research field.
> My advice would be to convert the TRMM data to a single netcdf file (which
> is much more suited for temporal + spatial datasets), and then process the
> data using command-line tools like CDO or NCO. In my experience this could
> be done with just a few commands.
> cdo: https://code.zmaw.de/projects/cdo
> nco: nco.sourceforge.net/
> BTW in which format did you get the TRMM data? most likely netcdf or hdf,,,
> let me know privately if you need a bit more help
> cheers
> Etienne
> On Thu, May 2, 2013 at 12:59 AM, Leo Kris Palao <lk.palao at gmail.com>wrote:
>> Hi *QGIS users*,
>> I am working with daily rainfall raster dataset of one decade acquired
>> from *TRMM*. We will use this as criteria for our suitability analysis
>> of a farming system. I want to derive the following:
>> 1. Mean daily rainfall *(*output is 365 raster files (representing *day
>> 1-day 365*) with each raster file contain the *mean daily rainfall*derived from one decade of daily rainfall data for a specific day
>> *)*; and
>> 2. After computing the mean daily rainfall for one decade, I want to
>> compute the rainfall sum with the interval of 10 days (per dekad).
>> is there a plugin in QGIS that I can use that will automate this process.
>> I know this is possible using a script, but I do not have a background yet
>> in scripting. Right now I am still reading Phyton programming. Also I think
>> it is possible to do this in R, but right now I am still learning R.
>> Any help will be much appreciated. Thank you very much.
>> -*Leo Kris Palao*
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130503/c4d57dfe/attachment.html>
