[Qgis-user] saga & grass, missing dependency with sextante
José Pedro Santos zpsantos1 at hotmail.com
Tue May 7 02:24:00 PDT 2013
I'm not using the version 1.09 of Sextante...try this: http://hub.qgis.org/issues/6538
Good luck.
B Regards,
José Santos
Date: Tue, 7 May 2013 10:55:44 +0200
To: zpsantos1 at hotmail.com
CC: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] saga & grass, missing dependency with sextante
    Il 07/05/2013 10:52, José Pedro Santos
      ha scritto:
      Hi Matteo,
        Go to Analysis - Sextante Options and configuration. Then check
        if the paths are correct or exist..try to activate the
        extensions (if they are not activate). I use QGIS 1.8 in Ubuntu
        12.04 and works fine.
    That's the problem: where can I define the paths? In Sextante -
    Options and configuration there isn't a way to do that.
    Cheers
    Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130507/ed09f687/attachment.html>
