[Qgis-user] problem with WFS and WMS connection server
Giacomo Rossi giacomo.rossi85 at gmail.com
Thu May 9 10:30:25 PDT 2013
I've solved the problem about the server wms connection. I've changed the
proxy from "http" to "default", thank you Paolo Cavallini for the advice
Il giorno 09/mag/2013 16:51, "Nick Ves" <vesnikos at gmail.com> ha scritto:
> I was able to connecto for the 2000 and 2006 CLC maps from the first group
> They're emtpy.
>  No go for the 2nd group, but no error message too.
> I'm using qgis 1.9 trunk on win7
> On Sun, May 5, 2013 at 11:54 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
>> A few things I noticed:
>> 1. the urls work for me, I get no error connecting. Maybe this is a
>> proxy/network/firewall issue. Can you try from another location and/or
>> computer
>> 2. I notice you are using qgis 1.7.4 not 1.8, I don't think that should
>> make much of a difference but it might.
>> Anyone else manage to get those to actually show data?
>> Thanks,
>> Alex
>> On 05/05/2013 01:17 PM, Giacomo Rossi wrote:
>>> I used these url:
>>> http://wms.pcn.minambiente.it/**ogc?map=/ms_ogc/WMS_v1.3/**
>>> Vettoriali/Corine_Land_**Cover1990.map<http://wms.pcn.minambiente.it/ogc?map=/ms_ogc/WMS_v1.3/Vettoriali/Corine_Land_Cover1990.map>
>>> Vettoriali/Corine_Land_**Cover2000.map<http://wms.pcn.minambiente.it/ogc?map=/ms_ogc/WMS_v1.3/Vettoriali/Corine_Land_Cover2000.map>
>>> Vettoriali/Corine_Land_**Cover2006.map<http://wms.pcn.minambiente.it/ogc?map=/ms_ogc/WMS_v1.3/Vettoriali/Corine_Land_Cover2006.map>
>>> http://wms.pcn.minambiente.it/**ogc?map=/ms_ogc/wfs/Corine_**
>>> Land_Cover1990.map<http://wms.pcn.minambiente.it/ogc?map=/ms_ogc/wfs/Corine_Land_Cover1990.map>
>>> Land_Cover2000.map<http://wms.pcn.minambiente.it/ogc?map=/ms_ogc/wfs/Corine_Land_Cover2000.map>
>>> Land_Cover2006.map<http://wms.pcn.minambiente.it/ogc?map=/ms_ogc/wfs/Corine_Land_Cover2006.map>
>>> No one of these links works...
>>> 2013/5/5 Paolo Cavallini <cavallini at faunalia.it>
>>>  Could you please post the address you use?
>>>> Thanks.
>>>> Giacomo Rossi <giacomo.rossi85 at gmail.com> ha scritto:
>>>>> Hello,
>>>>> I don't manage to connect qgis to some server, when I try to add layer
>>>>> WMS and WFS. After I click "connect" to add servers, an error message
>>>>> appears, "host not found". If you want, you can look my issue here:
>>>>> http://www.youtube.com/watch?**v=AfI6FTLMzLg<http://www.youtube.com/watch?v=AfI6FTLMzLg>Why does it happen? I use
>>>>> qgis 1.7.4.
>>>>> I need to know as soon as possible because I have to add corine land
>>>>> cover WFS servers from here:
>>>>> http://www.pcn.minambiente.it/**PCNDYN/catalogowfs.jsp?lan=it<http://www.pcn.minambiente.it/PCNDYN/catalogowfs.jsp?lan=it>
>>>>> Thank you
>>>>> Kind regards
>>>>> Giacomo Rossi
>> ______________________________**_________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130509/86eeeb16/attachment.html>
