[Qgis-user] kriging problems
matteo matteo.ghetta at gmail.com
Mon May 13 01:50:58 PDT 2013
Il 13/05/2013 10:08, Victor Olaya ha scritto:
> the version of SAGA that you are using does not contain the algorithm
> that is used to perform the test run, so it fails. SEXTANTE expects
> SAGA 2.0.8 to be installed in your system. I am afraid that you are
> using an older version. Updating it should solve your problem
I installed saga from packages (ubuntu 12.04) and actually it is the
version 2.0.7. I see I have to download and compile the newest version.
So this problem seems solved.
Thanks Victor!
Cheers
Matteo
