[Qgis-user] QGIS and Oracle native connection
Jürgen E. Fischer jef at norbit.de
Tue May 14 02:31:34 PDT 2013
Hi Jonathan,
On Mon, 13. May 2013 at 13:06:49 +0100, Jonathan Moules wrote:
> The first and most obvious thing is that it's incredibly slow to list the
> tables. I don't know how many tables were used in the test setup, but we
> have over a thousand spatial tables ranging from one row to 20 million on
> an Oracle Locator 10g setup that has about 50 concurrent users.
> In the best case scenario ("Only look in meta data table" and "Use
> estimated table metadata" both checked), it still takes a full two minutes
> to list all of the tables. If I don't have those checkboxes checked it
> takes much longer (scanning the table that has ~20million features alone
> takes about a minute!).
Can you work out which queries take particularly long (I added some progress
messages recently)?
> Does QGIS need to do all of the checks it does when actually listing the
> tables?
Well, QGIS needs to know which geometry types are present.  And that might take
long to determine.   It might be possible to do that lazy - ie. on demand
(introduce another level to the tree where the types in the geometry column
are.
> Its also impossible to "add" a table while the list is being generated so
> the user has to wait until its finished before being able to continue.
You can "stop" the detection and then pick what's already there.
> Panning. Again, fine with smaller datasets, but the larger ones cause
> issues.
Do you have numeric primary keys?  Otherwise QGIS must build a map that assigns
numeric keys to the primary keys (or ROWID if there isn't any primary key) on
the client side.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
