[Qgis-user] delete field doesn't work
Filipe Dias
filipesdias at gmail.com
Thu May 16 03:09:38 PDT 2013
Go to Help -> About and tell us what's written on:
Compiled against GDAL/OGR ->
If I remember correctly, only GDAL > 1.9 allows users to delete columns. If
that's the case, install the Table Manager plugin ou upgrade to QGIS 1.8.
Regards
On Thu, May 16, 2013 at 10:48 AM, Giacomo Rossi
<giacomo.rossi85 at gmail.com>wrote:
> With every shp...
> 2013/5/16 Alexandre Neto <senhor.neto at gmail.com>
>> In 1.7.4 I don't know, but in 1.8 it works like expected. In edit mode,
>> pressing "Delete Column" will give a list of all columns of the layer,
>> which one can select.
>> It happens with that specific shapefile, or any shapefile?
>> Alexandre Neto
>> On Thu, May 16, 2013 at 10:38 AM, matteo <matteo.ghetta at gmail.com> wrote:
>>> Il 16/05/2013 11:30, Giacomo Rossi ha scritto:
>>> Hello,
>>>> I've loaded one shapefile in qgis 1.7.4 but in the attribute table I
>>>> don't manage to push the button "delete field". How can I solve this
>>>> problem?
>>>> Thank you
>>>> Best regards
>>> I think that this features is not implemented in the 1.7 and in the 1.8
>>> version. But you can download the table manager plugin to add/delete and
>>> modify columns.
>>> Cheers,
>>> Matteo
>>> ______________________________**_________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130516/46ded75b/attachment.html>
