[Qgis-user] (Semi) automated classification of tree coverage from aerial photography
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri May 17 05:07:12 PDT 2013
Hi List,
  We're interested in doing some semi-automated classification of 3 (RGB)
and 4 band (RGB + near infrared) aerial photography to try and determine
the number of trees and tree coverage of our county (an area of about
2000sqkm).
I've done a small amount of searching and see there's a tutorial on
classification with QGIS (http://gis-lab.info/qa/dtclassifier-eng.html),
and at least one other plugin (
http://plugins.qgis.org/plugins/SemiAutomaticClassificationPlugin/).
Before we dive in, I figured I'd ask:
Does anyone have any experience with this using QGIS? Is there a preferred
plugin? Anything specific to trees I should know?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130517/024d8422/attachment.html>
