[Qgis-user] QGIS Openstreetmap plugin
Jo winfixit at gmail.com
Sat May 18 14:21:24 PDT 2013
I must admit I don't know sqlite nor spatialite. Is it possible to create
indexes, foreign key relations, stored procedures, triggers in it?
I get the impression QGIS is already very much integrated with PostGIS, so
for most people it shouldn't be a problem to install it. Once the
connection is set up, all the rest can be scripted.
I did have a look at the existing plugin and although I already noticed
that the ways layer contains the nodes with tags and it seems to know what
relations these nodes belong to, I can't seem to use the value of the
rcn_ref tag for the label.
Is the bug related to high node ids still in there? Can you point me to the
source code of the plugin? Who knows, maybe I can fix that.
Jo
2013/5/18 Stefan Keller <sfkeller at gmail.com>
> Hi Polyglot
> Just to be sure I'd like to point to the existing OSM plugin for QGIS
> [1], which deserves an evaluation and probably needs some care.
> Then, although I'm an active PostGIS (Postgres) supporter, I would
> recommend Spatialite (SQLite) instead, given you use case.
> It's more lightweight because it does not need a server installation
> and you probably only use it as a temporary store.
> Yours, Stefan
> [1] http://wiki.openstreetmap.org/wiki/QGIS_OSM_Plugin
> 2013/5/18 Jo <winfixit at gmail.com>:
> > Hi,
> > I'm a long time Openstreetmap contributor trying to wrap my brain around
> > understanding how to work with QGIS. Quite likely this means I follow the
> > opposite path of most.
> > I managed to convert WFS to SHP, load that SHP in JOSM, the java
> > openstreetmap editor and in PostGIS. Translating latin1 to UTF8 and
> > Lambert72 to WGS84. Even , to . as the decimal operator.
> > I also found how to style the data in the shape files.
> > So far so good.
> > Now I read the chapter in the manual on how to work with OSM data
> directly
> > in QGIS. What I'm missing is a way to work with the tags on the nodes
> and a
> > way to visualise route relations.
> > The best way is probably to give a concrete example. We have cycle node
> > networks. The nodes have rcn_ref tags, usually integers, sometimes START.
> > The nodes are members in network relations.
> > The ways between the nodes are members of route relations
> > The route relations are also members of the network relations.
> > I want the colour of the buffer around the nodes to be dependent on the
> > network relation they belong to.
> > I want the caption along the routes to come from the note tag of the
> route
> > relations. And I want to draw a buffer along their paths.
> > Is there a way to access the tags of the relations and the nodes?
> > Further down the line, I would love to be able to use QGIS to draw
> > spiderlike network diagrams of public transportation networks. With ways
> > coloured based on the bus lines passing there, 7 colours with an offset.
> > At some point I may write a Python plugin myself to work with OSM data.
> All
> > the data would be stored in PostGIS. Only the nodes would have
> geometries,
> > which can be uploaded to the OSM server. Ways would have geometries.
> > Relations would have geometries based on their type. But if ways or
> > relations are changed the geometry gets updated at the nodes level. Then
> all
> > geometries which use those nodes will have to be recalculated (with a
> > trigger function in PostGIS, I guess). I have no idea if such a solution
> > would be able to scale. Especially as I would also like to store historic
> > versions of the nodes, ways and relations in that DB.
> > The nodes layer would show all the nodes, not only the ones which have no
> > tags. Labels can be queried from the tags in the relations table as well
> > The ways layer would show all the non closed ways, not sure about the
> > roundabouts. Maybe all the ways which aren't areas.
> > The polygons layer would show all the closed ways (areas) and the
> > multipolygon relations. The buildings, the landuse, the boundaries.
> > The routes layer would show all the route relations
> > I have been giving this some thought:
> > CREATE TABLE users
> >   userid integer PRIMARY KEY,
> >   username text
> > WITH (
> >   OIDS=FALSE
> > ALTER TABLE users
> >   OWNER TO "Jo";
> > CREATE TABLE changesets
> >   csid integer PRIMARY KEY,
> >   cs_userid integer REFERENCES users,
> >   csts timestamp
> > WITH (
> >   OIDS=FALSE
> > ALTER TABLE changesets
> >   OWNER TO "Jo";
> > CREATE TABLE nodes
> >   nodeid bigint PRIMARY KEY,
> >   nd_csid integer REFERENCES changesets,
> >   ndversion integer,
> >   --ndts timestamp,
> >   geog geography
> > WITH (
> >   OIDS=FALSE
> > CREATE TABLE ways
> >   wayid integer PRIMARY KEY,
> >   wy_csid integer REFERENCES changesets,
> >   wyversion integer
> >   --wyts timestamp
> > WITH (
> >   OIDS=FALSE
> > CREATE TABLE rels
> >   relid integer PRIMARY KEY,
> >   rl_csid integer REFERENCES changesets,
> >   rlversion integer
> >   --rlts timestamp
> > WITH (
> >   OIDS=FALSE
> > CREATE TABLE keys
> >   keyid bigserial PRIMARY KEY,
> >   k text
> > WITH (
> >   OIDS=FALSE
> > CREATE TABLE vals
> >   valueid bigserial PRIMARY KEY,
> >   v text
> > WITH (
> >   OIDS=FALSE
> > CREATE TABLE tags
> >   tagid bigserial PRIMARY KEY,
> >   tg_nodeid bigint REFERENCES nodes,
> >   tg_wayid bigint REFERENCES ways,
> >   tg_relid bigint REFERENCES rels,
> >   tg_keyid bigint REFERENCES keys,
> >   tg_valueid bigint REFERENCES vals
> > WITH (
> >   OIDS=FALSE
> > CREATE TABLE waynodes
> >   wnid bigserial PRIMARY KEY,
> >   wn_way bigint REFERENCES ways,
> >   wn_node bigint REFERENCES nodes
> > WITH (
> >   OIDS=FALSE
> > CREATE TABLE relnodes
> >   rnid bigserial PRIMARY KEY,
> >   rn_rel bigint REFERENCES rels,
> >   rn_node bigint REFERENCES nodes
> > WITH (
> >   OIDS=FALSE
> > CREATE TABLE relways
> >   rwid bigserial PRIMARY KEY,
> >   rw_rel bigint REFERENCES rels,
> >   rw_way bigint REFERENCES ways
> > WITH (
> >   OIDS=FALSE
> > CREATE TABLE relrelations
> >   rrid bigserial PRIMARY KEY,
> >   rr_parent bigint REFERENCES rels,
> >   rr_child bigint REFERENCES rels
> > WITH (
> >   OIDS=FALSE
> > Until now I was considering to program this as stored procedures in
> PostGIS
> > and with Python from the command line, but it may make a lot more sense
> to
> > write a QGIS plugin in Python.
> > My goal is not only to be able to work with the data and visualise it. I
> > also need to find a way to prepare open data, available as shape files
> and
> > WFS, for integration in Openstreetmap and subsequently to do quality
> control
> > on it and to assure we keep current with changes coming from upstream and
> > the ability to create feedback reports on changes coming from the OSM
> > contributors, once they are vetted as genuine.
> > I'd love to hear your thoughts on all this. I wouldn't be surprised if
> > there's something I didn't think about.
> > Kind regards,
> > Polyglot
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130518/57622931/attachment.html>
