[Qgis-user] documentation for clip_shp_to_shp
Salvatore Larosa
lrssvtml at gmail.com
Tue May 21 08:36:10 PDT 2013
Hi Silver,
2013/5/21 Silver Ashen <silver.ashen at gmail.com>
> Again,
> I tried to use the "Script Runner" plugin. Here enclosed the script that I
> loaded.
> Nothing happening, do you know what I did wrong ?
This script [0] should works for both Python Console and Script runner [1].
For Python Console, saves it as clipper.py and
runs it with Run Script command, then type in console:
>>> import clipper
>>> clipper.run_script(iface)
the same result is obtained executing the code
with the 'Enter selected' command and then typing:
>>> run_script(iface)
not tested on Script Runner plugin, but I guess it should work anyway :-))
You also could consider to use SEXTANTE to do this kind of things!
Hope this helps.
Regards,
-SL
[0] - http://codepad.org/AlDzdVmi
[1] -
http://spatialgalaxy.net/2013/03/18/new-version-of-the-qgis-script-runner-plugin/
>> Hi,
>> Thanks for the tip, I didn't know the plugin.
>> Do you know where I can find some examples for "warning when the process
>> is finished" and loading result in the map canvas ?
>> I'm still a beginner in both python and python console.
>> I think that a few examples, a few "models" could help to save time
>> searching in the ocean of pyqgis :).
>> Bye
>> 2013/5/21 Salvatore Larosa <lrssvtml at gmail.com>
>>> Hi Silver,
>>> if you are using the development version of QGIS
>>> you can run the script from Python Console by using 'Run Script' or
>>> in the file editor, perhaps adding some statement to warn when the
>>> process is finished and to load
>>> the result into the map canvas.
>>> Alternately you can use the Script Runner plugin.
>>> Regards,
>>> -SL
>>>> Hello everybody,
>>>> I'm new on the mailing list. I'm a beginner with Python and Python
>>>> Console in QGIS.
>>>> I have a lot of shapefiles that I want to clip with one shapefile.
>>>> Instead of doing it manually, I want to try to use a script to do it.
>>>> By seeking on the mailing list archives, I found this :
>>>> http://osdir.com/ml/qgis-user-gis/2011-05/msg00122.html
>>>> This is very useful but I definitely do mistakes in filling the
>>>> different part of the code. Plus, I don't understand every parameters
>>>> (pref, suf ??).
>>>> Do you know where I can find some accurate documentation on
>>>> clip_shp_to_shp with examples ?
>>>> Where is the description of the Glob module ?
>>>> Thanks for your support.
>>>> Bye.
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Salvatore Larosa
>>> linkedIn: http://linkedin.com/in/larosasalvatore
>>> twitter: @lrssvt
>>> skype: s.larosa
>>> IRC: lrssvt on freenode
Salvatore Larosa
twitter: @lrssvt
skype: s.larosa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130521/efe92c71/attachment.html>
