[Qgis-user] Transparency in custom color table
Matt Boyd
mattslists at gmail.com
Wed May 22 20:56:50 PDT 2013
Yay,
I can see 1.9 something in the osgeo4w installer (experimental). Does that
have it?
Thanks
On Thu, May 23, 2013 at 1:51 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> In the latest QGIS build you can now use transparency in colour ramps
> http://nathanw.net/2013/05/21/alpha-in-qgis-colour-ramps-oh-yeah/
> You would just need to make a colour ramp and change the range you need to
> be transparency.
> - Nathan
> On Thu, May 23, 2013 at 1:48 PM, Matt Boyd <mattslists at gmail.com> wrote:
>> Hi everyone,
>> I've got a grid with a range of values, what I'd like to do is make
>> everything that is above and below a certain range transparent.
>> I'm able to select white in the colour table and not entering value
>> above a value seems to allow qgis to ignore that range but below that range
>> it shows white.
>> ie:
>> data starts at 6000
>> highest entry in color table is 2500 green
>> next entry 2000 light green.
>> next entry 1700 white
>> I
>> I'm using a linear interpolation and the values below 1700 are all white,
>> I'd like them transparent.
>> Is ti possible to enter a range of values for transparent pixels?
>> Thanks
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130523/a38a633f/attachment.html>
