[Qgis-user] ID's in shpaefile as names in kml ?
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Thu May 23 10:08:03 PDT 2013
You can use OGR creation options. In the 'Save vector layer as...' dialog,
use the 'OGR creation options -> Data source' text edit to write the
following:
NameField=<your_attribute>
Then export to KML and load your layer in Google Earth. The name of the
placemark should correspond to the one in your attribute.
See the OGR formats page for KML [1] as a reference.
Best regards
[1] - http://www.gdal.org/ogr/drv_kml.html
On Thu, May 23, 2013 at 5:32 PM, gvSIGMac <gvsig.mac at gmail.com> wrote:
> I did not find the reference now, but if I recall right you need a field
> called "name". Whatever is in this field will go to the KML file as name.
> ________________________________
> Agustin
> On 23/05/2013, at 17:38, Agustin Lobo <alobolistas at gmail.com> wrote:
> > Hi!
> > Is there any way to make that the ID field of the table become
> > the name field in the kml? Currently I get all points as "no name"
> > in GE (there is no field name in the kml). I have to edit the kml
> > by hand in GE.
> > Alternatively, is there any way to create this name field in a more
> > systematic way?
> > Thanks
> > Agus
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
___________________________ ___ __
Ricardo Garcia Silva
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130523/d5d52b4a/attachment.html>
