[Qgis-user] Fwd: extract the Lat/long coordinates on polygon layer
skampus stefano.campus at regione.piemonte.it
Fri May 24 02:57:32 PDT 2013
the first thing i can suggest you is to use sextante. search "polygon
vertices to points" and a point shape file will be created. this shape has,
as attribute, the information to group by the points as belonging to same
generating polygons.
then, go in edit mode, and add $x and $y new colums/fields
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fwd-extract-the-Lat-long-coordinates-on-polygon-layer-tp5055498p5055513.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
