[Qgis-user] Fwd: problems with installation in ubuntu 12.10
Etienne Tourigny etourigny.dev at gmail.com
Wed May 29 04:48:56 PDT 2013
---------- Forwarded message ----------
From: Luis M. Ruiz E. <geografoaplicado at gmail.com>
Date: Tue, May 28, 2013 at 11:35 PM
Subject: Re: [Qgis-user] problems with installation in ubuntu 12.10
To: Etienne Tourigny <etourigny.dev at gmail.com>
No se pudo cargar PyQGIS.
El soporte para Python estará deshabilitado.
  File "", line 1, in
RuntimeError: the sip module implements API v9.0 to v9.2 but the
qgis.core module requires API v8.1
Versión de Python:
2.7.4 (default, Apr 19 2013, 18:35:44)
[GCC 4.7.3]
Versión de QGIS:
1.7.5-Wroclaw 'Wroclaw', exported
Ruta de Python:
['/usr/share/qgis/python', '/home/geografo/.qgis/python',
'/home/geografo/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.7', '/usr/lib/python2.7/plat-i386-linux-gnu',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
'/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
these is the message when i start QGis
help me please¡¡¡¡¡¡¡¡¡¡¡¡¡¡
2013/5/28 Etienne Tourigny <etourigny.dev at gmail.com>
> On Tue, May 28, 2013 at 10:42 AM, Luis M. Ruiz E. <
> geografoaplicado at gmail.com> wrote:
>> Hello Comunity¡¡¡
>> apologies for my lowest level of english, i have a big problem with QGis
>> in Ubuntu 12.1
>> I installed the packages qgis python-qgis, and all right, but when i
>> install the plugins open layers and cad plugin, poligonizer and others and
>> i try to open the aplications, qgis to close unexpectedly.
>> not created a log file, but show a window with a message what say is a
>> problem with the packages of gdal and gdal grs or something this, i dont
>> have much idea of programing or these things, but i try to remove the
>> packages and the repositories to uninstall and reinstall qgis, and now,
>> dont work none of the packages and the python plugins manager  :(
> If you post the exact errors here perhaps someone can help you.
>> i need a lot of the python plugins to work, and i tried all the solutions
>> to solve this problem, help me please, i dont want to change mi Operating
>> System, and format my pc, help me please.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130529/ff64f0a3/attachment.html>
