[Qgis-user] disabled snap!!
Gerardo Jimenez
gejst5 at hotmail.com
Thu May 30 05:55:08 PDT 2013
In order to snap to vertex in a layer you must set a tolerance setting, either in map units or pixels. I usually use 15 pixels and works fine. What tolerance setting did you use?
Gerardo Jiménez Delgado
Instituto de Investigaciones Antropológicas
Universidad Nacional Autónoma de México
Ciudad Universitaria s/n
Coyoacan 04510
Mexico City
Mexico
56 22 95 16
Date: Thu, 30 May 2013 09:59:41 +0200
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] disabled snap!!
Hello everybody, I don't manage to snap on the vertex one polygon that I want to create inside a shapefile, because I need to create records in the attribute table for a land use job.
I've enabled editing and snap to vertex and segment in snap options, but I continue not to be able to snap the new polygon that I want to make. I've qgis 1.8.
Please someone help me, thank you a lot!
Giacomo Rossi
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130530/ff35a1e3/attachment.html>
