[Qgis-user] Qgis-user Digest, Vol 87, Issue 80
AGBO Yawo Ségbéaya perdejumo at gmail.com
Fri May 31 10:42:57 PDT 2013
Dear
How to put:
1- a title and legend for a map
2- to bring map to the composer
Thanks.
*Agbo Yawo Ségbéaya*
Géologue Explorateur
Chef de Dvision Prospection Minière
Direction des Recherches Géologiques et Minières (DRGM) de la Direction
Générale des Mines et de la Géologie (DGMG)
06 Avenue Sarakawa, BP: 356 Lomé-Togo,
                                   Tel Service :+22822213001; Fax :
+22822213193,                                      Mobile : +22890396980 Skype:
segbeaya74;                                                        E-mail:*
agboyawo at yahoo.fr* ou yawo74 at hotmail.fr
2013/5/31 <qgis-user-request at lists.osgeo.org>
> Send Qgis-user mailing list submissions to
>         qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>    1. Affine Transformation (Diego Mo)
>    2. Re: Fwd: problems with installation in ubuntu 12.10
>       (Luis M. Ruiz E.)
>    3. Could not load pyqgis -- qgis.core.module not using API v9.0,
>       requires v8.1 (Neil Redgate)
>    4. Problems with Value relation (Antonio Vico)
>    5. Re: Could not load pyqgis -- qgis.core.module not using API
>       v9.0, requires v8.1 (Paolo Cavallini)
>    6. Sextante - help of algorithms (skampus)
>    7. Re: Could not load pyqgis -- qgis.core.module not using API
>       v9.0, requires v8.1 (Neil Redgate)
>    8. Re: Sextante - help of algorithms (Alexander Bruy)
> Message: 1
> Date: Fri, 31 May 2013 11:56:43 +0200 (CEST)
> From: Diego Mo <diego.mo at csi.it>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Affine Transformation
> Message-ID:
> 1673703145.196929.1369994203223.JavaMail.open-xchange at comunica.csi.it>
> Content-Type: text/plain; charset=UTF-8
> Hello
> I would like to apply an affine transformation to a vector layer not
> georeferenced using only QGIS
> Browsing the web I found this interesting post:
> http://foss4gis.blogspot.it/2011/05/computing-and-applying-affine.html
> Trying to use only QGIS, I thought it might be a solution to rasterize the
> vector layer, georefer with the Georeferencer plugin and use the word file
> to
> get the parameters. But you can save the word file only applying a linear
> transformation.
> Having determined a set of double points, someone has a suggestion on how
> to get
> in QGIS the 6 parameters to be used with the plugin Affine Transformation
> or
> with the library v.transform of Grass via SEXTANTE?
> Thanks in advance
> Diego Mo
> Message: 2
> Date: Fri, 31 May 2013 06:32:35 -0500
> From: "Luis M. Ruiz E." <geografoaplicado at gmail.com>
> To: Qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Fwd: problems with installation in ubuntu
>         12.10
> Message-ID:
> CANEt_L-pB8E6MUYMqYJACqRPrg-fQzaZJgi_YWAGEaLS9mWbpQ at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Solved???????????????
> i made something what i think is no recomended, but work????, i started in
> console mode, nautilus, and delete the python-qgis folder configuration,
> the repositories, and did a simple update, add the raining repository and
> install ???????????
> QGis Rock
> QGis Avanza??????????????????????
> 2013/5/29 Paolo Cavallini <cavallini at faunalia.it>
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > Il 29/05/2013 13:48, Etienne Tourigny ha scritto:
> > > ---------- Forwarded message ----------
> > > From: *Luis M. Ruiz E.* <geografoaplicado at gmail.com <mailto:
> > geografoaplicado at gmail.com>>
> > > Date: Tue, May 28, 2013 at 11:35 PM
> > > Subject: Re: [Qgis-user] problems with installation in ubuntu 12.10
> > > To: Etienne Tourigny <etourigny.dev at gmail.com <mailto:
> > etourigny.dev at gmail.com>>
> > > No se pudo cargar PyQGIS.
> > > El soporte para Python estar? deshabilitado.
> > > Versi?n de QGIS:
> > > 1.7.5-Wroclaw 'Wroclaw', exported
> > Please upgrade to 1.8 and report back.
> > All the best.
> > Paolo Cavallini - Faunalia
> > www.faunalia.eu
> > Full contact details at www.faunalia.eu/pc
> > Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> > -----BEGIN PGP SIGNATURE-----
> > Version: GnuPG v1.4.12 (GNU/Linux)
> > Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> > iEYEARECAAYFAlGmIP4ACgkQ/NedwLUzIr7LNwCeNzFGLM1BuZ54bkUP7byjGUMR
> > 7+MAoI5z/5qTMmFCXcpLqWEyYQznw7Ea
> > =Dvby
> > -----END PGP SIGNATURE-----
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130531/330bec5c/attachment-0001.html
> Message: 3
> Date: Fri, 31 May 2013 12:42:54 +0100
> From: Neil Redgate <nredgate at ndres.co.uk>
> Subject: [Qgis-user] Could not load pyqgis -- qgis.core.module not
>         using API v9.0, requires v8.1
> Message-ID: <1370000574.32582.2.camel at office.ndres.co.uk>
> Content-Type: text/plain; charset="utf-8"
> Hi,
> I am writing in the hope that someone can advise me as to how I can
> resolve the problem that I have.
> My setup-
> OS: Debian, testing (Jessie)
> QGIS: 1.8 (wheezy) and [on a separate machine] 1.9 master (nightly
> build)
> Python: 2.7.5
> GCC: 4.7.3
> Following recent upgrades of (I believe these are the relevant packages)
> python-sip: 4.14.6-1
> python-qt4: 4.10.1-1
> when I launch QGIS, I get the following error message regarding pyqgis
> with both QGIS versions
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
>   File "", line 1, in
> RuntimeError: the sip module implements API v9.0 to v9.2 but the
> qgis.core module requires API v8.1
> Python version:
> 2.7.5 (default, May 20 2013, 11:53:03)
> [GCC 4.7.3]
> QGIS version:
> 1.9.0-Master 'Master', exported
> Having searched the internet & QGIS stackexchange/fora, the only
> suggestion is to update QGIS, 1.7.4 -> 1.8 as the sip module (4.14.6, on
> PC) is newer than that being looked for by qgis.core.module.
> Following this advice of upgrading to the latest version, I upgraded
> QGIS on one of my machines to run 1.9 and I still get the same problem.
> Is there a way that I can edit qgis.core.module (and/or other files) to
> look & accept the latest sip module; or if this is not the way forward,
> can you please advise (in simple terms for me as I am not a programmer)
> what I need to do to get QGIS working with its plugins.
> Thanking you for your time
> yours
> Neil
> Neil Redgate
> Neil Redgate
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130531/ea220dcd/attachment-0001.html
> Message: 4
> Date: Fri, 31 May 2013 13:58:40 +0200
> From: Antonio Vico <avicomartin at gmail.com>
> Subject: [Qgis-user] Problems with Value relation
> Message-ID: <51A89070.9090209 at gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Hi everyone,
> I'm testing the new "Value relation" in fields and I get some problems.
> I load a geometry layer with geometryes, a dbf layer with values (equal
> structure to Nathan Woodrow indicates in his Melbourne Workshop video)
> and associate values. I load a ui form (101 fields) and all work
> perfectly, but when I want save the style for retreive later, this not
> work. Layer relation are missing.
> If I no change dbf layer relations are preserved but if I close the dbf
> layer and open again, relation are missing (reload style not preserve
> layer relation)
> Looking in my saved style file I observed that the reference to the dbf
> layer is a "timestamp" layer (name layer and numbers that I think is a
> timestamp related to the layer). In this situation I loaded my saved
> style, modified only one field and saved. The "timestamp" is different
> only for the field modified and only this field maintain layer relation.
> If I use a editor with the style file and change unmodified "timestamps"
> according with the new obtained, relation are preserved.
> I observed that reference to the ui file has problems too and saving
> styles in database have the same problems.
> I tested the latest qgis-master in osgeo4w distribution and the nigth-built
> A idea about how to solve this problem?
> Message: 5
> Date: Fri, 31 May 2013 14:47:48 +0200
> From: Paolo Cavallini <cavallini at faunalia.it>
> Subject: Re: [Qgis-user] Could not load pyqgis -- qgis.core.module not
> Message-ID: <51A89BF4.2030804 at faunalia.it>
> Hash: SHA1
> Il 31/05/2013 13:42, Neil Redgate ha scritto:
> > Hi,
> resolve the
> > My setup-
> > QGIS: 1.8 (wheezy) and [on a separate machine] 1.9 master (nightly build)
> > Python: 2.7.5
> > GCC: 4.7.3
> with both QGIS
> > versions
> >   File "", line 1, in
> qgis.core module
> > requires API v8.1
> yes, I had a symmetrical problem (see qgis-dev ML). Please upgrade qgis,
> or downgrade
> python-sip.
> All the best.
> www.faunalia.eu
> iEYEARECAAYFAlGom/QACgkQ/NedwLUzIr5cJACgtFxYLCQpNxs70CUduPQ/rACr
> AbcAoKWos0rY8Vg3N5XWxQB2jpHRXRnZ
> =LpdE
> Message: 6
> Date: Fri, 31 May 2013 06:56:45 -0700 (PDT)
> From: skampus <stefano.campus at regione.piemonte.it>
> Subject: [Qgis-user] Sextante - help of algorithms
> Message-ID: <1370008605445-5057185.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> hi,
> in sextante provided with qgis dev i can't see anymore the help of each
> module (specifically from grass and saga) that was present in the "help"
> tab.
> in the sextante options it was possible to set the path of help files.
> now it seems that this is not possible.
> is it right?
> s.
> http://osgeo-org.1560.x6.nabble.com/Sextante-help-of-algorithms-tp5057185.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Message: 7
> Date: Fri, 31 May 2013 16:18:42 +0100
> Message-ID: <1370013522.7455.27.camel at office.ndres.co.uk>
> > > Hi,
> resolve the
> > > My setup-
> build)
> > > Python: 2.7.5
> > > GCC: 4.7.3
> packages) -
> with both QGIS
> > > versions
> > >   File "", line 1, in
> qgis.core module
> > > requires API v8.1
> or downgrade
> > python-sip.
> > All the best.
> Hi Paolo,
> Very many thanks for your quick reply.
> I think I would prefer to upgrade qgis rather than downgrade python-sip
> as the downgrade may result in other package downgrades which may affect
> other packages.
> I have already upgraded to qgis v1.9 through the nightly builds (sid)
> and still have the same problem.
> Is there a higher version available for downloading onto a Debian
> distribution?
> The QGIS download page refers to v1.8 as being the current version.
> Googling for a v2 download produces no sites
> There are many references to qgis v2 on the qgis-developers mailing list
> but I cannot find any downloads for this. The messages on the developers
> mailing list suggest that v2 is due to be released in the near future
> Could you point me in the right direction to download v2 please?
> very many thanks,
> Neil
> Neil Redgate
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130531/3ff99e70/attachment-0001.html
> Message: 8
> Date: Fri, 31 May 2013 21:03:40 +0400
> From: Alexander Bruy <alexander.bruy at gmail.com>
> To: skampus <stefano.campus at regione.piemonte.it>
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Sextante - help of algorithms
> Message-ID:
> CALuHMPD2NYJZTWizbKLUOj_62a4e5BCsWsuO22KOb+Ff3qpn4g at mail.gmail.com>
> Hi,
> help files moved to the separate repo and propably will be added to
> QGIS user guide
> 2013/5/31 skampus <stefano.campus at regione.piemonte.it>:
> > hi,
> > tab.
> > is it right?
> > s.
> Alexander Bruy
> End of Qgis-user Digest, Vol 87, Issue 80
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130531/f2c60392/attachment.html>
