[Qgis-user] Symbolize Line with two symbols
Bernhard Ströbl bernhard.stroebl at jena.de
Mon Nov 11 03:02:26 PST 2013
and thank you for the answer. I had already tried this solution (2) but
as I mentioned in my original mail if the lines have many corners
(partly with 90 degrees) the second symbol is not on the line any more.
example:
symbol 1 position is at line start (position 0/0) symbol 1 interval is
10 (map unists) x shift for symbol 2 is 5 (map units), 90 degree angle
is at 3/0 (line bend northward). Then symbol two is drawn at position
5/0 but should IMHO be drawn at position 3/2
illustration:
     ___1_____2
1___|  2
if the line itself is not drawn this would look like this (guess where
the line goes :):
        1     2
1      2
my aim is to get this (which at least approximates the line):
        1    2
     2
1
Bernhard
Am 11.11.2013 11:40, schrieb Zirneklitis:
> The Marker Offset in X direction is what you are looking for.
> Bernhard Ströbl wrote:
>> I am trying to use two different symbols to symbolize a line. The result
>> should look like this:
>> x o x o
>> solutions tried:
>> 1) make a marker line (type interval) with two markers; result: the two
>> markers are painted on top of each other
>> What I would need is a shift of symbol 2 _along_ the line (no in x/y
>> direction)
> Qgis-user mailing list
__________ Information from ESET Mail Security, version of virus signature database 9030 (20131111) __________
The message was checked by ESET Mail Security.
http://www.eset.com
