[Qgis-user] Buffer segments to approximate
Horst Düster horst.duester at kappasys.ch
Tue Nov 19 08:29:36 PST 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Ludovic
The number of segments depends on the exactness of the results you
expect. If you create a circle buffer around a point with radius of 1
the area of the circle will running against PI with increasing number of
segments. Now you have to decide how many digits of PI are expected as
exact.
mPoint = QgsGeometry().fromPoint(QgsPoint(0,0))
for i in range(100):
    circle = mPoint.buffer(1,i+1)
    print str(i)+"  "+str(circle.area())
All the best
Horst
Dr. Horst Düster
Kappasys
Alte Bernstrasse 13
CH-4500 Solothurn
Tel.: +41 (0) 32 514 00 40
Mobil: +41 (0) 76 408 51 06
eMail: horst.duester at kappasys.ch
skype: horstduester
Twitter: moazagotl
Web: www.kappasys.ch
qgiscloud.com - The easiest way to publish your maps
Am 19.11.2013 17:07, schrieb Andreas Neumann:
> Hi,
> Buffers for points are round. There are also round corners for
line/polygon buffers, depending on the linecap styles and line join
styles. QGIS and simple features can only display straight lines. The
number of the segements to approximate means the higher the number, the
more vertices you will have for a circle approximation.
> See also http://postgis.net/docs/manual-2.1/ST_Buffer.html as an
explanation for buffer styles and segments.
> Andreas
> Am 2013-11-19 14:57, schrieb ludo:
>> Hi all
>> Is there anyone could tell me what is "segments to approximate" in the
>> buffer tool ?
>> I know that if I increase this value, there's more nodes on my buffer
>> but I don't know what is it exactly and how we can choose this value.
>> Thanks
>> Regards
>> Ludovic
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJSi5HwAAoJENxaj+NbOI6Sn+wIALBPHd0u2rGP+y4wlgP7OUBp
6qVhZNXQiklvaXS4iPQL0Q1MBAb1ywVmeXHsCPu7N4wD9LphoBlHpS0MgaeAN7xp
ujM1ertLny1dxkDLSJB+OefJgQs2irAMEO5j0n6Kg+r2UBRsMkbTH8SO/lFKEy79
C6NbOCUQ6wp9s/FLk1EzyjN8RbDxhyLGvnRIc6PasJ8W/PCO8KgwMyDu6iVSSd5C
6nZOkCbX/Hxlqu0ZrSoU4PGIXP56ZgJd0yCxkKDRfJc6FdAzBJK1VnIroiZNtwxi
AI1R7Sz8jD6SGg+tIo9SNz4IgbWUGocRMwfbihDjxfl0TNPs6LQ6nRALbBM0CCo=
=g/0H
-----END PGP SIGNATURE-----
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131119/f0b6d01f/attachment.vcf>
