[Qgis-user] Pan Map, Zoom in, Zoom out
Andreas Neumann a.neumann at carto.net
Thu Nov 28 08:26:05 PST 2013
Hi Peter,
There is always one active tool - depending on what you do. As an
example - if you are in zoom in mode and then change to the "Identify"
mode the tool switches to "Identify" and the navigation mode is
discontinued.
If you are in editing mode, navigation only works with shortcuts (e.g.
the blank key and mouse wheel) until you leave the editing mode.
In general there is always one tool active. If you select a new tool,
the previous tool will be inactive.
Andreas
Am 28.11.2013 17:09, schrieb HPETER784 at aol.com:
> This sounds like a simple question.
> Windows 7 Home Premium
> QGIS 2.0
> Once activated, I cannot find out how to de-activate the above buttons (Pan
>  Map, Zoom in, Zoom out, etc).  I can switch from one to another, but never
>  disable them all.  This means that I can do no work at all on the  maps.
> Sorry if I am being dense.
> Peter  Hutchinson,
> _hpeter784 at aol.com_ (mailto:hpeter784 at aol.com)
> Qgis-user mailing list
