[Qgis-user] MGRS Coordinates: a recurrent question
Andre Joost andre+joost at nurfuerspam.de
Thu Nov 28 20:49:27 PST 2013
Backporting to the list:
> Am 28.11.2013 20:02, schrieb Luca Arzeni:
>> Thanks to all, I was not clear in my question...
>> I already have the code to do the conversion... beside it, the
>> geograpphic lib is already available in python and, since it's the
>> code under proj, I think I would use it if I should not use mine
>> https://pypi.python.org/pypi/geographiclib
>> My question is: I would like to user MGRS as one of the others
>> native CRS available on the system (choosing it in systems dialog
>> and so on).
>> What is the proper way to plug my code inside QGIS to have it
>> available in all the system?
>> Since the people on proj seems to be aginst implementing MGS within
>> proj, my first thought was to write a wrapper around proj, so I
>> will pass the reqests to proj UNLESS I found a MGRS CRS, which
>> should be tackled by my routines.
>> Is this a reasonable way to go? or is there any other way, more
>> "QGISish"?
>> If this is the proper way, where I shoud hook my conversion code?
>> Thanks, larzeni
