[Qgis-user] install qgis 2.0.1-2 win7 64
j.allain at agglo-paysflers.fr j.allain at agglo-paysflers.fr
Tue Oct 1 05:21:36 PDT 2013
 Thanks,
The problem comes from the autosandbox of avast antivirus :( !!!
go qgis !
Jonathan A
-----Kalle Kronholm <kalle at kronholm.cc> a écrit : -----
A : Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
De : Kalle Kronholm <kalle at kronholm.cc>
Date : 01/10/2013 12:15
Cc : j.allain at agglo-paysflers.fr, "qgis-user at lists.osgeo.org" <Qgis-user at lists.osgeo.org>
Objet : Re: [Qgis-user] install qgis 2.0.1-2 win7 64
Hi
I had similar issues with the standalone QGIS 64 bits installer. But after running the OSgeo4W installer for 64 bits, I now have QGIS running.
Kalle
2013/10/1 Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
They both worked fine for me when I tried them. Might it be a permissions issue? Also did you change where it went?
Cheers,
Jonathan
On 1 October 2013 10:57,  <j.allain at agglo-paysflers.fr> wrote:
    Hello,
I've downloaded qgis2.0.1 standalone installer for winx86 and x86_64. Both programs finishes correctly but each times, the "QGIS DUFOUR" repository is not created and nothing is installed. Has anybody met this behaviour ?
Thanks
Jonathan A
_________________________
 Qgis-user mailing list
 http://lists.osgeo.org/mailman/listinfo/qgis-user
 This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131001/feec3ddc/attachment.html>
