[Qgis-user] How to set lat/long boundaries for a map
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Oct 1 06:28:49 PDT 2013
Hi Joe,
In QGIS 2.0 I think this is possible with the "Export" tool.
Open the Processing toolbar.
Type in "export" into the search box at the top.
One of the results is "Export raster layer". Double click this.
It doesn't appear to have any help, however it looks fairly
self-descriptive. If you want to use a bounding box, enter it into the
"subset based on georeferenced coordinates" field. If you click on the
ellipses (...) you'll see some options to help do it manually.
Export it to wherever you want it to go.
It seemed to work OK when I did it for a quick test just now.
Regards,
Jonathan
On 1 October 2013 13:53, Joe Lertola <joe at joelertola.com> wrote:
> Hello,
> I am very new to Qgis so I apologize if this is information I should have
> gotten from the documentation. But I have been looking for a while and have
> not found the answer.
> I downloaded a couple of tiles of elevation data from
> http://nationalmap.gov/viewer.html. I am able to bring them into Qgis and
> display them on screen. What I want to do is crop the map to specific
> lat/long boundaries and export it as an image file. So far it seems like
> what you see on screen is what you get when you export the map. I have not
> found a way so set specific boundaries. Is this possible and if so how?
> Thanks for any help.
> -Joe
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131001/34bbeb3b/attachment.html>
