[Qgis-user] Problems with the plugin Grass in QGIS 2.0
William Kyngesburye woklist at kyngchaos.com
Tue Oct 1 16:34:27 PDT 2013
that should be fixed in the latest package (2.0.1-3).
On Oct 1, 2013, at 10:28 AM, massimiliano crea wrote:
> I am a new user of qgis 2.0. I need to create digital terrain models starting from contour lines or from vector geo-referenced tiff. I tried but when I use grass does not work.
> Carry the error message:
> " v.in.ogr dsn=/Users/macpro/Downloads/curvespear.shp/curvespear.shp output=curvespear1 snap=-1 min_area=0.0001 -o
> Over-riding projection check
> Layer: curvespear
> Default driver / database set to:
> driver: dbf
> database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> dyld: Library not loaded: @loader_path/../../libgrass_dbmidriver.dylib
>   Referenced from: /Applications/QGIS.app/Contents/MacOS/grass/driver/db/dbf
>   Reason: image not found
> dbmi: Protocol error
> Unable to start driver
> Unable open database by driver  "
> I do know how to fix it?
> thanks
> Massimiliano Crea
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
