[Qgis-user] QGIS 2.0 in Portable App
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Oct 3 06:30:50 PDT 2013
This is probably better placed on the developer list (cc'd).
However I believe I read a message on there suggesting it was being ported
over.
Jonathan
On 3 October 2013 04:01, maning sambale <emmanuel.sambale at gmail.com> wrote:
> Has anyone tried using QGIS 2.0 in USB Portable App [0]?
> There are instructions and build with QGIS 1.8 here [1].
> [0] http://portableapps.com/
> [1]
> http://cyclatron.users.sourceforge.net/menuitem-howto-soft-alterations/7-article-howto-softalteration-qgisportable-1-8
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131003/f11d44fb/attachment.html>
