[Qgis-user] Polygon coloring
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri Oct 4 05:02:27 PDT 2013
If you google around ("qgis manual download pdf") there are several PDF
documents. I doubt any are for 2.0, but for basic stuff QGIS hasn't changed
too much between versions. I.e.:
http://manual.linfiniti.com/
http://nathanw.net/2013/01/06/qgis-manuals/
etc.
Jonathan
On 3 October 2013 11:27, KLGan <1klgan at gmail.com> wrote:
> Thanks Andreas,
> I am new to QGIS, and for a moment thought this is not possible. Glad to
> know these are basic stuffs in gis :-)
> Will browse the manual (how I wish the manual is available for download)
> Thanks
> KLGan
> On 3 October 2013 17:54, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> This is very basic GIS stuff. Please consult the QGIS manual for this.
>> As a hint:
>> You need to define either of:
>> * a rule
>> * a category
>> * assign a column that contains color values
>> These are available in the layer properties and in the "Styles" tab.
>> All of these are described in the QGIS manual:
>> http://www.qgis.org/en/docs/user_manual/working_with_vector/vector_properties.html#style-menu
>> Good luck,
>> Andreas
>> Am 03.10.2013 09:44, schrieb KLGan:
>> > Hi,
>> > I have a layer with many polygons. I want to change the color of some of
>> > the polygons. How can I do this in QGIS?
>> > Currently changes apply to all the polygons, not individual one.
>> > Thanks :-)
>> > KLGan
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131004/436c5967/attachment.html>
