[Qgis-user] Saving layers
Lene Fischer
lfi at life.ku.dk
Thu Oct 17 07:58:19 PDT 2013
Hello Jonathan,
Do you think about saving as a project?
When you save the project - it include path, CRS, colour/style, label, printcomposer - everything.
http://qgis.org/en/docs/user_manual/introduction/qgis_configuration.html#project-properties
Regards
Lene Fischer
Fra: qgis-user-bounces at lists.osgeo.org [qgis-user-bounces at lists.osgeo.org] på vegne af Jonathan Moules [jonathanmoules at warwickshire.gov.uk]
Sendt: 17. oktober 2013 15:36
Til: qgis-user at lists.osgeo.org
Emne: [Qgis-user] Saving layers
Hi List,
I'm wondering if QGIS can save links to layers as stand alone files, similar to how ArcMap does it.
I know I can save the style, but I want to save everything about the layer including data location etc in a file which I can then share with others. The style only saves the style.
I can't seem to find such a function - is there one?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131017/3ef23802/attachment.html>
