[Qgis-user] Export map to pdf defective
Andreas Neumann a.neumann at carto.net
Mon Oct 21 00:49:09 PDT 2013
 Hi Nelson,
 This is probably not a bug. It sounds like you have the Atlas serial
 printing active. In the print composer have a look at the "Atlas
 Generation" panel and make sure it is not enabled.
 Hope this helps.
 Andreas
 On Sun, 20 Oct 2013 17:58:22 -0200, Nelson Fava wrote:
> Dear Sirs.,
> First of all congratularions for the new Quantum GIS 2.0.
> I was playing with it last friday, October 18yh., succeeded in
> georreferencing high resolution satelite images, very happy. When I
> decided to export the map I constructed made to pdf format, there was
> a series of at least 10 (ten) maps generated, one of the whole map I
> made and the others were fragments of the main map, each of them from
> a different map of the "mother map". Can you solve this bug?
> Thanks in advance,
> Sincerely,
> Nelson Fava.
