[Qgis-user] Topological editing of two vector layers
Alexandre Neto senhor.neto at gmail.com
Mon Oct 21 01:41:29 PDT 2013
Hello Deon,
If you have the chance, exporting both your layers to Postgres\Postgis,
would allow you to, for each district geometry, run ST_Snap[1] against its
related province geometry. With the correct tolerance, this might solve a
big part of your Boundary differences.
Even tho, you would need to check the result and correct the rest of the
problems manually.
Best regards,
Alexandre Neto
[1] http://postgis.org/docs/ST_Snap.html
On Mon, Oct 21, 2013 at 8:10 AM, Harish <harry.om2000 at gmail.com> wrote:
> If the layers are digitized by different agencies and dissolving is time
> consuming for each next higher level, then the automatic snapping of
> boundaries within tolerance distance, with keeping one layer as correct
> layer will be a useful feature.
> Regards
> On Tue, Oct 15, 2013 at 7:25 PM, Carlos Cerdán <sig.upagu at gmail.com>wrote:
>> ... or you can disolve your districts to obtain new provinces and leave
>> the old layer
>> Good luck
>> Carlos Cerdán
>> 2013/10/15 Lene Fischer <lfi at life.ku.dk>
>>>  Hello Deon
>>> You can use the function Avoid Intersection while digitizing.
>>> In this way you avoid overlap - but not gaps.
>>> Read more about this issue in the usermanual
>>> http://qgis.org/en/docs/gentle_gis_introduction/06_topology.html?highlight=snap
>>> http://qgis.org/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html?highlight=snap
>>>  Regards
>>> Lene Fischer
>>> *Fra:* qgis-user-bounces at lists.osgeo.org [
>>> qgis-user-bounces at lists.osgeo.org] på vegne af Pretorius Deon -
>>> Lieutenant Colonel [PretoriusDeon at saps.gov.za]
>>> *Sendt:* 15. oktober 2013 06:55
>>> *Til:* 'qgis-user at lists.osgeo.org'
>>> *Emne:* [Qgis-user] Topological editing of two vector layers
>>>   Hi, Iam new to QGIS. I have two boundary vector  layers, the one
>>> exist of polygons of all the provinces and the other of all the districts.
>>> The district boundaries must be aligned with the provincial boundaries.
>>> Since there is so much errors that needs alignment and rectification  I was
>>> wondering if there isn’t an easier way as to snap to the boundaries without
>>> to drag each vertex which is very time consuming.  Is there perhaps a way
>>> where the whole identified segments/vertex of the districts can be aligned
>>> easier to the provincial boundaries.
>>> Regards
>>> Deon Pretorius
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131021/915c70bb/attachment.html>
