[Qgis-user] db-manager (temporary tables)
António M. Rodrigues
amcrgrodrigues at gmail.com
Tue Oct 22 04:57:13 PDT 2013
The thing is I have some custom functions which output temp tables. And it
would be useful to be able to explore these tables in db-manager.
I guess it shouldn't be too difficult to tweak dbmanager.
I was looking at the source code for but unfortunately my knowledge of
pyqgis is not quite there (maybe one day... :--) ).
António
2013/10/22 Andreas Neumann <a.neumann at carto.net>
> Hi,
> You can load query results in db-manager.
> Just create a query in db-manager, select the primary key column and the
> geometry column and load it.
> Works fine for me.
> Andreas
> Am 22.10.2013 13:42, schrieb António M. Rodrigues:
> > Hi,
> > Is there a way to access temporary tables through db-manager?
> > From what I get, this is only possible through layer->add postgis layer
> > (also not available in the browser panel).
> > Thanks,
> > António
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131022/d79fa0ea/attachment.html>
