[Qgis-user] Landsat RGB band ratio images with Qgis
Radim Blazek
radim.blazek at gmail.com
Wed Oct 23 04:04:46 PDT 2013
On Mon, Oct 7, 2013 at 6:14 PM, BLANDENIER Lucien
<lucien.blandenier at unine.ch> wrote:
> Dear all,
> I would like to know if there a possibility to make some RGB band ratio with Landsat images, like (5/3, 5/1, 7/5).
You can write you own renderer in Python, example:
from PyQt4.QtGui import QColor
from qgis.core import *
from qgis.utils import iface
class MyRenderer ( QgsRasterRenderer ):
def __init__( self ):
QgsRasterRenderer.__init__(self)
def block ( self, bandNo, extent, width, height ):
block2 = self.input().block ( 2, extent, width, height )
block3 = self.input().block ( 3, extent, width, height )
block4 = self.input().block ( 4, extent, width, height )
block = QgsRasterBlock ( QGis.ARGB32_Premultiplied, width, height, 0 );
for r in range(0,height):
for c in range(0,width):
v2 = block2.value( r, c )
v3 = block3.value( r, c )
v4 = block4.value( r, c )
color = QColor ( v4, v3, v2 )
block.setColor( r, c, color.rgb() )
return block
renderer = MyRenderer()
iface.activeLayer().pipe().set( renderer )
In the renderer you can blend colors like you want.
This is somewhat experimental, it won't be saved in project, you
cannot change params of your renderer in properties GUI.
Radim
> I searched on Internet but found nothing relevant.
> Regards
> Lucien
> Qgis-user mailing list
