[Qgis-user] [Qgis-developer] Opening view or table using DBManager locks it in postgis
Giuseppe Sucameli
brush.tyler at gmail.com
Thu Oct 24 15:25:56 PDT 2013
Hi Alexandre,
On Tue, Oct 22, 2013 at 10:58 AM, Alexandre Neto <senhor.neto at gmail.com>wrote:
> Yes, I believe it is. At least the fact that only closing QGIS releases
> the locks.
I've pushed a fix for this issue.
Please, confirm if it works now.
Cheers.
Giuseppe
> You can even create several locks on the same table if you keep removing
> and adding the same table.
> But, is it expected that a QGIS client can lock a postgis view in such way
> that I can not even run a trigger on a related table? When I tried, QGIS
> just hangs until I close the process in Postgresql. The opposite happens
> when I try to delete a View via Pgadmin that is opened in QGIS, pgadmin
> hangs until I close QGIS.
> Thanks,
> Alexandre
> On Mon, Oct 21, 2013 at 8:56 PM, Nyall Dawson <nyall.dawson at gmail.com>wrote:
>> Shared locks for select queries are ok (that's how postgres works) but
>>> they must be released once cursors are closed (or even deleted).
>>> Please, file a ticket on the QGIS trac [1].
>> There's already a report with some details regarding this:
>> http://hub.qgis.org/issues/7679
>> I think it's related.
>> Cheers,
>> Nyall
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131025/dce14816/attachment.html>
