[Qgis-user] map composer: cannot set portrait
Alexandre Neto
senhor.neto at gmail.com
Mon Oct 28 14:25:00 PDT 2013
Hello Tim,
If you are new to Map composing with QGIS, I advice you to take a look into
the Print Composer
Chapter<http://www.qgis.org/en/docs/user_manual/print_composer/print_composer.html>of
the User
Manual <http://www.qgis.org/en/docs/user_manual/index.html>. That said, You
need to change your Map item scale in the main properties or it's extent.
Best regards,
Alexandre Neto
On Sun, Oct 27, 2013 at 11:34 PM, Tim Michelsen <timmichelsen at gmx-topmail.de
> wrote:
> > Are you changing the size and position of your map item?
> OK, that was the problem.
> I just changed page settings...
> Now, the issue is that the actual map (the visible part of the selected
> layers) is way smaller incomparsion to the map item. So the composer
> seems to waste a lot of space around the layers.
> How can I prevent that?
> Regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131028/ddbb9698/attachment.html>
