[Qgis-user] QGIS 2.0 on openSUSE 12.3 - Processing Plugin
Murkor mharte at ozemail.com.au
Thu Oct 31 04:11:11 PDT 2013
Glad to offer a little service to the community, Angelos.  I work as a
GIS professional in an office where the big commercial outfit (you know
who) is the corporate standard.  A couple of my colleagues and I
continue to push the benefits of opensource and believe QGIS has
developed into a quality tool.  Keep up the good work.
Cheers,
Mike
Michael Kevin Harte BS MS
ABN:  80745603160
3 Merrill Place
Lammermoor Beach
QLD 4703
Australia
+61 7 4933 7176
On 28/10/2013 9:27 AM, Angelos Tzotsos [via OSGeo.org] wrote:
> Hi Mike,
> Thank you for your detailed report, we will have a look at this.
> Best,
> Angelos
> On 10/24/2013 04:54 AM, Murkor wrote:
> > I've installed QGIS 2.0.1-Dufour on a desktop with a relatively new
> install
> > of openSUSE 12.3 OS 64bit.
> > On executing QGIS I got a message box telling me the plugin
> "Processing"
> > could not be loaded from all the directories in the QGIS path.
> > Opening the plugin manager and choosing the "Installed" option on
> the left I
> > could see 'Processing" listed with red text in the list of plugins.
>  There
> > was also a category for "Problems"  (or something like that - it is
> gone now
> > because I applied a fix) where "Processing" was shown.  In either case
> > highlighting "Processing" showed the message highlighted in yellow
> that this
> > plugin required "QSCI".
> > I shutdown QGIS and started up the YaST Software Manager.  I
> searched for
> > "QSCI".  The search returned three (3) pythonscintilla packages and
> two (2)
> > libscintilla packages.  I installed all packages EXCEPT
> libscintilla-devel
> > (libqscintilla2-8, python-qscintilla, python-qscintilla-sip, and
> > python3-qscintilla).
> > I restarted QGIS and got the same message telling me "Processing"
> could not
> > be loaded.
> > Again, opening the plugin manager and choosing the "Installed"
> option on the
> > left I could see 'Processing" listed with red text in the list of
> plugins.
> > Highlighting "Processing" showed the message that this plugin required
> > "psycopg2".
> searched for
> > "psycopg2".  The search returned four (4)  packages.  I installed
> all four
> > (4) packages (python-psycopg2, python-psycopg2-doc,
> python3-psycopg2, and
> > python3-psycopg2-doc).
> > I restarted QGIS and no longer received a message regarding
> "Processing".
> > The "Processing" menu item now shows up in the menu and I can
> activate the
> > "Processing Toolbox" which I assume is the QGIS 2 evolution of the
> SEXTANTE
> > toolbox.
> > Searching for the solution to this problem I see that it is a
> reported bug
> > (Bug #8710 - cmake mises missing Qsci -
> http://hub.qgis.org/issues/8710) and
> > the last entry in the History list of this bug report, from Georg
> > Reutelsterz, mentions the install of the qscintilla package, but not
> the
> > installation of the psycopg2 package.  It might be the difference
> between
> > openSUSE 12.3 and openSUSE 12.1 (the version Georg mentioned).
> > I hope this note helps other installers/users of QGIS 2 on platforms
> that
> > show the error for the the "Processing" plugin component installation.
> > Cheers,
> > Mike
> > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/QGIS-2-0-on-openSUSE-12-3-Processing-Plugin-tp5085479.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > [hidden email] </user/SendEmail.jtp?type=node&node=5086002&i=0>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
> [hidden email] </user/SendEmail.jtp?type=node&node=5086002&i=1>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/QGIS-2-0-on-openSUSE-12-3-Processing-Plugin-tp5085479p5086002.html
> To unsubscribe from QGIS 2.0 on openSUSE 12.3 - Processing Plugin,
> click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5085479&code=bWhhcnRlQG96ZW1haWwuY29tLmF1fDUwODU0Nzl8MTc1NjE4NjM2Mw==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-2-0-on-openSUSE-12-3-Processing-Plugin-tp5085479p5086812.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131031/cf488edc/attachment.html>
