[Qgis-user] Qgis-user Digest, Vol 90, Issue 71
Leo Kris Palao lk.palao at gmail.com
Sun Sep 1 19:20:26 PDT 2013
Hi Stefan,
Thanks for taking the time reply. It did work the Sextante > Saga > Grid
Tools > Reclassify Grid Values tool.
Thank you.
-Leo
On Fri, Aug 30, 2013 at 4:21 PM, <qgis-user-request at lists.osgeo.org> wrote:
> Send Qgis-user mailing list submissions to
>         qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>    1. Converting null(no data) to 0 (Leo Kris Palao)
>    2. OSX - QGIS not loading Grass plugin (Graeme Merrall)
>    3. How to show images of arster and vector files? (Yoshiaki Tsuzuki)
>    4. Re: Converting null(no data) to 0 (skampus)
>    5. Re: How to show images of arster and vector files?
>       (Alexandre Neto)
> Message: 1
> Date: Fri, 30 Aug 2013 13:44:15 +0800
> From: Leo Kris Palao <lk.palao at gmail.com>
> To: QGIS Mailing List <qgis-user at lists.osgeo.org>, a.maunahan at irri.org
> Subject: [Qgis-user] Converting null(no data) to 0
> Message-ID:
> CAMktv+2RizZbED107BKCRY9kq_H+DOx+tZKuS1B+5Ob5m5kgKg at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Dear QGIS Community,
> Good Day!
> We are currently processing srtm_5 minutes resolution data for asia. We
> have polygons (125 features) that covers 9 raster cells each. Our task is
> to compute the average cell values using the zonal statistics plugin. In
> our data we have negative values and NULL values; we managed to mask those
> negative values using raster calculator -- our syntax is *srtm at 1 > 0) *
> srtm at 1*. But we are having a problem dealing with the NULL values. We
> tried
> the raster > conversion > translate module and set the No Data value to 0.
> It did convert the No Data to 0 values as indicated in the metadata. But
> when we clicked on the pixels the value is -3.40282e+38. My observation
> was, in the polygons where the pixel values are mix of actual elevation
> values and -3.40282e+38, it creates inconsistency in the results. For
> instance, we have a polygon that covers 9 cells -- the 7 cells contains
> elevation values ranging from 4 to 4.59, and the other two cells have
> values -3.40282e+38, the result was: *MEAN = -7.56182992530064e+22* and
> *SUM
> = -6.80564693277058e+22*. If the NULL values have been successfully
> converted to 0 the result should be MEAN = 2.90103 and SUM = 26.10925.
> How can I do this properly.
> Thank you in advance for any suggestion and help.
> Thanks,
> -Leo
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130830/6fff0796/attachment-0001.html
> Message: 2
> Date: Fri, 30 Aug 2013 16:04:14 +1000
> From: Graeme Merrall <dasfreak at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] OSX - QGIS not loading Grass plugin
> Message-ID:
>         <CAG5_Ya0yc00m47Pe=VjNYZeRnsLX-f8LR1foZ=
> gdcCLRiykndQ at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> I'm trying to get the Grass plugin to load in QGIS in OSX Mountain Lion.
> QGIS ver: 1.8.0 (kyngchaos)
> Grass ver: 6.4 (kyngchaos)
> GDAL ver: 1.10 (kyngchaos with Grass plugin)
> Python: 2.7.2
> The error I'm getting is:
> Failed to load
> /Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassplugin.so
> (Reason: Cannot load library
> /Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassplugin.so:
> (dlopen(/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassplugin.so,
> 5): Library not loaded:
> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.6.4.2.dylib
>   Referenced from:
> /Applications/QGIS.app/Contents/PlugIns/qgis/libgrassplugin.so
>   Reason: image not found))
> Following errors include libgrassprovider and libgrassrasterprovider.
> >From from searching about I saw very old references to fftw install
> (tried,
> no joy) and tweaking your LD_LIBRARY_PATH.  For LD_LIBRARY_PATH I exported
> both the QGIS plugins dir and Grass lib dir and started QGIS from the
> command line - still didn't work.
> Can anyone point out what's going wrong?
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130830/387a4dea/attachment-0001.html
> Message: 3
> Date: Fri, 30 Aug 2013 07:11:21 +0000
> From: Yoshiaki Tsuzuki <y.tsuzuki at uq.edu.au>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] How to show images of arster and vector files?
> Message-ID:
>         <F97F5CA2885B5341BCA3735A9FBD9027C02BC2 at uqexmdb8.soe.uq.edu.au>
> Content-Type: text/plain; charset="us-ascii"
> Dear QGIS user ML
> I am trying to read datasets in the Queensland State, Australia. I could
> open and show image of the DEM file by changing the file properties from
> "no stretch" to "streatch to MinMax", however, I am struggling with other
> raster and vector files. These files can be seen in the TOC, however, no
> image in the map window. I look forward to your help.
> (1) Landcover data, raster
> 03/06/2013  12:31 PM            17,020 Metadata_QLD_LANDCOV_2001_25M_X.htm
> 03/06/2013  12:31 PM            22,285 Metadata_QLD_LANDCOV_2001_25M_X.xml
> 03/06/2013  12:30 PM             6,150 QLD_LANDCOV_2001_25M_X.aux
> 03/06/2013  12:30 PM                94 QLD_LANDCOV_2001_25M_X.tfw
> 03/06/2013  12:30 PM        35,406,889 QLD_LANDCOV_2001_25M_X.tif
> 29/08/2013  12:34 PM             6,435 QLD_LANDCOV_2001_25M_X.tif.aux.xml
> 03/06/2013  12:31 PM            17,314 QLD_LANDCOV_2001_25M_X.tif.vat.dbf
> (2) Drainage area, vector
> 21/12/2010  05:42 PM       127,924,762 IQ_QLD_DRAINAGE_25K.DAT
> 03/12/2010  01:58 PM       152,186,318 IQ_QLD_DRAINAGE_25K.dbf
> 21/12/2010  05:42 PM         8,822,384 IQ_QLD_DRAINAGE_25K.ID
> 21/12/2010  05:42 PM       337,022,976 IQ_QLD_DRAINAGE_25K.MAP
> 03/12/2010  01:59 PM               145 IQ_QLD_DRAINAGE_25K.prj
> 30/08/2013  04:40 PM        16,369,060 IQ_QLD_DRAINAGE_25K.qix
> 30/08/2013  04:43 PM             1,993 IQ_QLD_DRAINAGE_25K.qml
> 09/12/2010  01:23 PM        18,276,732 IQ_QLD_DRAINAGE_25K.sbn
> 09/12/2010  01:23 PM           193,716 IQ_QLD_DRAINAGE_25K.sbx
> 03/12/2010  01:59 PM       681,175,604 IQ_QLD_DRAINAGE_25K.shp
> 03/12/2010  02:02 PM        17,644,868 IQ_QLD_DRAINAGE_25K.shx
> 21/12/2010  04:32 PM               247 IQ_QLD_DRAINAGE_25K.tab
> 03/12/2010  02:03 PM            27,138 Metadata_IQ_QLD_DRAINAGE_25K.htm
> 03/12/2010  02:03 PM            18,563 Metadata_IQ_QLD_DRAINAGE_25K.xml
> Kind regards
> Yoshi
> Yoshiaki Tsuzuki, Engineering, Architecture and Information Technology
> (EAIT), The University of Queensland, St Lucia, QLD 4072, Australia
> (Office) +61 (0)7 3365 3912: The number has been changed because of the
> moving of office; (Mobile) +61 (0)410 230 355
> E-mail: y.tsuzuki at uq.edu.au<mailto:y.tsuzuki at uq.edu.au>;
> tsuzuki.yoshiaki at gmail.com<mailto:tsuzuki.yoshiaki at gmail.com>
> Homepage: http://sites.google.com/site/yoshiakitsuzuki/Home
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130830/0bd48b35/attachment-0001.html
> Message: 4
> Date: Fri, 30 Aug 2013 01:16:50 -0700 (PDT)
> From: skampus <stefano.campus at regione.piemonte.it>
> Subject: Re: [Qgis-user] Converting null(no data) to 0
> Message-ID: <1377850610601-5075169.post at n6.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> you can reclassify null values by means of SEXTANTE
> QGIS 1.8 --> Analysis --> Sextante toolbox --> SAGA --> Grid Tools -->
> QGIS dev --> Processing --> Toolbox --> Geoalgorithms --> Raster -->
> Edition
> --> Reclassify Grid Values
> it is the same function coming from SAGA.
> keep the values of all the cells and change only the cell values equal to
> NULL
> s.
> http://osgeo-org.1560.x6.nabble.com/Converting-null-no-data-to-0-tp5075130p5075169.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Message: 5
> Date: Fri, 30 Aug 2013 09:21:30 +0100
> From: Alexandre Neto <senhor.neto at gmail.com>
> To: Yoshiaki Tsuzuki <y.tsuzuki at uq.edu.au>
> Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] How to show images of arster and vector
>         files?
> Message-ID:
> CA+H0G_H7M6bRykgz0mYkhh2GAGcvmhbf3mk0tjmT5uZgF28x6g at mail.gmail.com>
> Content-Type: text/plain; charset="windows-1252"
> Hello,
> Did you try, for each of your layers, do Right-click > Zoom to layer
> extent?
> It might be a CRS problem.
> Alexandre Neto
> On Fri, Aug 30, 2013 at 8:11 AM, Yoshiaki Tsuzuki <y.tsuzuki at uq.edu.au
> >wrote:
> >  Dear QGIS user ML****
> > ?no stretch? to ?streatch to MinMax?, however, I am struggling with other
> > image in the map window. I look forward to your help.****
> > (1) Landcover data, raster****
> > 03/06/2013  12:30 PM             6,150 QLD_LANDCOV_2001_25M_X.aux****
> > 03/06/2013  12:30 PM                94 QLD_LANDCOV_2001_25M_X.tfw****
> > 03/06/2013  12:30 PM        35,406,889 QLD_LANDCOV_2001_25M_X.tif****
> QLD_LANDCOV_2001_25M_X.tif.aux.xml*
> QLD_LANDCOV_2001_25M_X.tif.vat.dbf*
> > (2) Drainage area, vector****
> > 21/12/2010  05:42 PM       127,924,762 IQ_QLD_DRAINAGE_25K.DAT****
> > 03/12/2010  01:58 PM       152,186,318 IQ_QLD_DRAINAGE_25K.dbf****
> > 21/12/2010  05:42 PM         8,822,384 IQ_QLD_DRAINAGE_25K.ID****
> > 21/12/2010  05:42 PM       337,022,976 IQ_QLD_DRAINAGE_25K.MAP****
> > 03/12/2010  01:59 PM               145 IQ_QLD_DRAINAGE_25K.prj****
> > 30/08/2013  04:40 PM        16,369,060 IQ_QLD_DRAINAGE_25K.qix****
> > 30/08/2013  04:43 PM             1,993 IQ_QLD_DRAINAGE_25K.qml****
> > 09/12/2010  01:23 PM        18,276,732 IQ_QLD_DRAINAGE_25K.sbn****
> > 09/12/2010  01:23 PM           193,716 IQ_QLD_DRAINAGE_25K.sbx****
> > 03/12/2010  01:59 PM       681,175,604 IQ_QLD_DRAINAGE_25K.shp****
> > 03/12/2010  02:02 PM        17,644,868 IQ_QLD_DRAINAGE_25K.shx****
> > 21/12/2010  04:32 PM               247 IQ_QLD_DRAINAGE_25K.tab****
> Metadata_IQ_QLD_DRAINAGE_25K.htm***
> Metadata_IQ_QLD_DRAINAGE_25K.xml***
> > Kind regards****
> > Yoshi****
> > (EAIT), The University of Queensland, St Lucia, QLD 4072, Australia****
> > moving of office; (Mobile) +61 (0)410 230 355****
> > E-mail: y.tsuzuki at uq.edu.au; tsuzuki.yoshiaki at gmail.com****
> > Homepage: http://sites.google.com/site/yoshiakitsuzuki/Home****
> > Qgis-user at lists.osgeo.org
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130830/b7c1b7eb/attachment.html
> End of Qgis-user Digest, Vol 90, Issue 71
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130902/bc503006/attachment.html>
