[Qgis-user] Saga not working with "In processing" aka sextante
Victor Olaya
volayaf at gmail.com
Fri Sep 6 04:00:04 PDT 2013
those might be problems with an algorithm definition (now for some
algorithms we need two, one for each version, if the algorithm has
changed)
I will check the case for that particular algorithm
thanks!
2013/9/6 skampus <stefano.campus at regione.piemonte.it>:
> in windows too there are ( I have...) some problems.
> for example, the "merge shapes" module doesn't work with 2.0.8 and
> compatibility checked, but it works perfectly with 2.1 (and compatibility
> un-checked, obviously).
> s.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Saga-not-working-with-In-processing-aka-sextante-tp5076404p5076432.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
