[Qgis-user] Qgis-user Digest, Vol 91, Issue 21
Telmo Nunes pinanunes at gmail.com
Fri Sep 6 14:17:05 PDT 2013
I'm sorry for the late reply but yes is like Goyo says
I did the following, allways with the same result:
-I corrected the path to C:\OSGeo4W\apps\saga, activated 2.0.8
compatibility mode (checked saga version there and is indeed 2.0.8).
- Instaled saga 2.1.0 changed the path and disabled compatibility mode
- Same as previous with compatibility mode activated.
I've tried this on the following wgis version:
QGIS version2.1.0-MasterQGIS code revision7030b1aCompiled against
Qt4.7.1Running
against Qt4.7.1Compiled against GDAL/OGR1.9.2Running against
GDAL/OGR1.9.2Compiled
against GEOS3.3.8-CAPI-1.7.8Running against GEOS3.3.8-CAPI-1.7.8PostgreSQL
Client Version8.3.10SpatiaLite Version4.1.1QWT Version5.2.1PROJ.4
Version480QScintilla2
Version2.6.2This copy of QGIS writes debugging output.
Not ure if it matters to solve the problem, but the data providers listed
as:
Available QGIS Data Provider Plugins
   1. WFS data provider
   2. Delimited text data provider
   3. GDAL provider
   4. GPS eXchange format provider
   5. GRASS data provider
   6. GRASS raster provider
   7. Memory provider
   8. MSSQL spatial data provider
   9. OGR data provider (compiled against GDAL/OGR library version 1.9.2,
   running against GDAL/OGR library version 1.9.2)
   10. Oracle data provider
   11. OWS meta provider
   12. PostgreSQL/PostGIS data provider
   13. SpatiaLite data provider
   14. SQL Anywhere data provider
   15. OGC Web Coverage Service version 1.0/1.1 data provider
   16. OGC Web Map Service version 1.3 data provider
This does not happen with all operations but i guess those that use SAGA
all give the same error. It looks like just a path error since not even the
UI for the function loads.
I hope you can solve it, since sextante is THE plugin. It has saved me many
hours. Keep up the good work!
Best regards
Telmo
2013/9/6 <qgis-user-request at lists.osgeo.org>
> Send Qgis-user mailing list submissions to
>         qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>    1. Re: Compile Qgis Server without GUI (J?rgen E. Fischer)
>    2. Re: Compile Qgis Server without GUI (samuelmesa at gmail.com)
>    3. Re: Saga and sextante (Goyo)
>    4. Categorized - value and label (Lene Fischer)
> Message: 1
> Date: Fri, 6 Sep 2013 14:54:51 +0200
> From: J?rgen E. Fischer <jef at norbit.de>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Compile Qgis Server without GUI
> Message-ID: <20130906125451.GA28539 at norbit.de>
> Content-Type: text/plain; charset=iso-8859-1
> Hi Samuel,
> On Fri, 06. Sep 2013 at 07:44:16 -0500, samuelmesa at gmail.com wrote:
> >    Hi all, is possible to compile and install QGIS Server without GUI,
> >    without requiring the QT4 libraries?. This is to work in a server
> >    environment.
> Without GUI yes (WITH_DESKTOP=FALSE, WITH_MAPSERVER=TRUE), but that'll
> also include
> Qt.
> J?rgen
> J?rgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstra?e 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM)                                   IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Message: 2
> Date: Fri, 6 Sep 2013 08:23:42 -0500
> From: "samuelmesa at gmail.com" <samuelmesa at gmail.com>
> To: J?rgen E. <jef at norbit.de>,  qgis-user <qgis-user at lists.osgeo.org>
> Message-ID:
>         <CAN5q7SV=URa53fmzkNgrx=UZeYVyRJyLEwsxDRLa_==
> gq9em9Q at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Thanks J?rgen for your answer.
> Regards,
> Samuel Mesa
> 2013/9/6 J?rgen E. <jef at norbit.de>
> > Hi Samuel,
> > >    environment.
> > also include
> > Qt.
> > J?rgen
> +49-4931-918175-31
> +49-4931-918175-50
> FreeNode
> > Qgis-user at lists.osgeo.org
>    / v \
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130906/50e3b4c8/attachment-0001.html
> Message: 3
> Date: Fri, 6 Sep 2013 15:36:26 +0200
> From: Goyo <goyodiaz at gmail.com>
> To: Victor Olaya <volayaf at gmail.com>
> Cc: qgis-user <qgis-user at lists.osgeo.org>, Telmo Nunes
>         <pinanunes at gmail.com>
> Subject: Re: [Qgis-user] Saga and sextante
> Message-ID:
> CACNjSPSna_BE2NtKtmX4q_vM0vXhR98O3xfNdboCfwr+iznJRQ at mail.gmail.com>
> Content-Type: text/plain; charset=UTF-8
> 2013/9/6 Victor Olaya <volayaf at gmail.com>:
> > Telmo
> > Can you confirm that you are using the version provided with osgeo4w
> > (which is still 2.0.8) and you have enabled 2.0.8 compatibility (which
> > is not enabled by default)?
> I can confirm this. SAGA 2.0.8 is installed from OSGeo4W, SAGA
> provider activated, SAGA 2.0.8 comptibility enabled, SAGA folder
> D:/OSGeo4w/apps\saga (which I changed to D:\OSGeo4w\apps\saga without
> any effect).
> Clicking on execute any SAGA algorhithm this message appears:
> Missing dependency.This algorithm cannot be run :-(
> This algorithm requires SAGA to be run.Unfortunately, it seems that
> SAGA is not installed in your system, or it is not correctly
> configured to be used from QGIS
> Click here to know more about how to install and configure SAGA to be
> used with QGIS
> Goyo
> Message: 4
> Date: Fri, 6 Sep 2013 17:03:32 +0000
> From: Lene Fischer <lfi at life.ku.dk>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Categorized - value and label
> Message-ID:
> <38497AD9CA059C42AA3451EFEFF0378E471617AC at P2KITMBX04WC02.unicph.domain>
> Today I?ve been working with Style manager and added 82 new colours. Then
> made a categorized colour for the same 82 items.... Hard work  - but easy
> to share :-)
> So now I have a value and a label which is alike
> But now I would like to add a new coloum to the label.
> Is there a way to "join" a coloum to the label?
> Regards
> Lene Fischer
> End of Qgis-user Digest, Vol 91, Issue 21
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130906/e9ab9d6b/attachment.html>
