[Qgis-user] csv import issue
Hugo
hfpmartins at gmail.com
Sat Sep 7 06:28:39 PDT 2013
Ola Telmo,
OGR supports an additional file (.csvt) to specify the types of the
attribute columns of a csv file. Check these blogs:
http://sigsemgrilhetas.wordpress.com/2013/05/07/visualizar-dados-dos-censos-2011-com-o-qgis/
http://anitagraser.com/2011/03/07/how-to-specify-data-types-of-csv-columns-for-use-in-qgis/
Cheers,
On Sat, Sep 7, 2013 at 1:20 PM, Telmo Nunes <pinanunes at gmail.com> wrote:
> I have a recurrent issue when loading csv files.
> When one of the fields is a text field only with numeric characters qgis
> allways imports that field as numeric. You might ask why would I want a
> field with numeric characters to be a text field, and the answer is that
> one dataset I usually use, the administrative regions regions are coded
> with numeric characters as text...for example 011312 that is converted to
> 11312 even if the values in the csv file have the quote markers (" or ')
> and I define that on the csv import dialog (see below a csv example)
> I have found diferent workarround solutions for this issue like:
> - converting the code on the original shapefile to numeric
> - importing the csv to a database and loading from the database
> - creating a dummy record where i put a letter character in that field
> They all work, but is just annoying to do this over and over and adds some
> unecessary steps in the data analysis workflow (for example when importing
> a satscan gis file output to map the clusters). My question is:
> - Am I missing something here?
> - If not, is it possible to fix that?
> Below is a portion of a csv file, if you manage to import the file and
> keep the LOC_ID field as text please let me know.
> 'ID';'LOC_ID';'CLUSTER';'P_VALUE';'CLU_OBS';'CLU_EXP';'CLU_ODE';'CLU_RISK';'LOC_OBS';'LOC_EXP';'LOC_ODE';'LOC_RISK'
> 1;'070105';1,00;1,0e-17;283,00;72,06;3,92;13,44;0,00;0,00;0,00;0,00
> 2;'070101';1,00;1,0e-17;283,00;72,06;3,92;13,44;0,00;2,58;0,00;0,00
> 3;'070103';1,00;1,0e-17;283,00;72,06;3,92;13,44;0,00;2,72;0,00;0,00
> 4;'071002';1,00;1,0e-17;283,00;72,06;3,92;13,44;47,00;3,12;15,03;17,07
> My best regards
> Telmo Nunes
> Qgis-user mailing list
Hugo Martins
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130907/6f10cb6a/attachment.html>
