[Qgis-user] QGis-Map-Server "Map Loading" Problem Ubuntu 12.04
Gunnar Oehmichen oehm8895 at uni-landau.de
Sun Sep 8 05:57:05 PDT 2013
Ok, got it:
### If necessary replace the paths in index html (projects)
cd ~/www/qgis-web-client/site
sed -i "s/home\/web/home\/guna\/www/g" index.html
### do the same for the globaloptions.js
cd ~/www/qgis-web-client/site/js
sed -i "s/home\/web/home\/guna\/www/g" GlobalOptions.js
Since the web-client was cloned into /home/guna/www and not into /home/web
Short question, in index.html :
<h2>Your local maps</h2>
         <div>
           <ul class="map-list">
             <li class="map-item"><a
href="qgiswebclient.html?map=/home/guna/www/qgis-web-client/projects/helloworld.qgs">HelloWorld
(Projection WGS84 - EPSG 4326)</a></li>
             <!--<li class="map-item"><a
href="qgiswebclient.html?map=/home/guna/www/qgis-web-client/projects/naturalearth_110million.qgs&format=image/png&visibleLayers=Ocean,Land,Glaciated
Areas,Lakes,Rivers&maxExtent=">NaturalEarth (Projection WGS84 - EPSG
4326)</a></li>-->
href="qgiswebclient.html?map=/home/guna/www/qgis-web-client/projects/naturalearth_110million.qgs">NaturalEarth
           </ul>
Why is naturalearth listed two times. Once in <li /li>
and second  in <!--<li ...?
Thanks,
Gunnar
Gunnar Oehmichen
Quantitative Landscape Ecology
Institute for Environmental Sciences
University Koblenz-Landau
Fortstrasse 7
76829 Landau
Germany
http://www.uni-koblenz-landau.de/landau/fb7/umweltwissenschaften/landscape-ecology/Staff/gunnaroehmichen
