[Qgis-user] How to personalize popup (hoverPopup) content in qgis-web-client?
Andreas Neumann a.neumann at carto.net
Thu Sep 12 04:53:25 PDT 2013
Hi Antonio,
In newer webclient/server releases you also have to set up the display
field in the layer properties --> display tab.
There are plans to also support the HTML expressions, but up to now they
are not yet supported.
Let me know if it still does not work after you set the display field in
QGIS desktop.
Thanks,
Andreas
Am 12.09.2013 12:43, schrieb Antonio Vico:
> Hi all,
> I try to personalize hoverPopup contents like this sample:
> http://webgis.uster.ch/maps/stadtentwaesserung/wc_anlagen?format=image/jpeg&visibleLayers=WC-Anlagen,Gemeindegrenze,Pixelkarten%20und%20%C3%9Cbersichtsplan&searchtables=&startExtent=692000,241500,700100,249000&maxExtent=692000,241500,700100,249000
> but I can't do it (In my tests only show name layer qgis 1.8 and name
> layer and ).
> Reading FeatureInfoDisplay.js file, comments say that hoverPopup can
> display the field named "toolbox" but I have tested to create "toolbox"
> field in my sample but in hoverPopup only layer name appear (contents in
> toolbox field are missing).
> In this same file, the showFeatureInfoHover function use 'tooltip'
> attribute and I tested again with a field named "tooltip" in my data
> sample but content not show.
> Can somebody explain how to include data in hoverPopup?
> Qgis-user mailing list
