[Qgis-user] How to personalize popup (hoverPopup) content in qgis-web-client?
Antonio Vico avicomartin at gmail.com
Thu Sep 12 10:20:57 PDT 2013
Hi Giovanni,
In initial comment (line 15) show 'toolbox' and in line 99 show
'tooltip'. Is for this that I tested all options without success.
I use a git version downloaded at 19-07-2013 that not include
tooltipTemplates. I will test the latest version next weekend/week. Can
you advance how to include fields in GlobalOptions?
On 12/09/13 19:04, G. Allegri wrote:
> That's why I invited you to consider to configure a template inside
> GlobalOptions...
> Sent from Nexus
> Il giorno 12/set/2013 19:00, "Antonio Vico" <avicomartin at gmail.com
> <mailto:avicomartin at gmail.com>> ha scritto:
>     Hi Andreas,
>     I have tested set up the display field and it works, but only show
>     the field selected (I want more than one field, like the sample I
>     mentioned in my first email). If I use the HTML option, in qgis
>     client work fine but in qgis-web-client not (only show layer name).
>     On 12/09/13 13:53, Andreas Neumann wrote:
>         Hi Antonio,
>         In newer webclient/server releases you also have to set up the
>         display
>         field in the layer properties --> display tab.
>         There are plans to also support the HTML expressions, but up
>         to now they
>         are not yet supported.
>         Let me know if it still does not work after you set the
>         display field in
>         QGIS desktop.
>         Thanks,
>         Andreas
>         Am 12.09.2013 12:43, schrieb Antonio Vico:
>             Hi all,
>             I try to personalize hoverPopup contents like this sample:
>             http://webgis.uster.ch/maps/stadtentwaesserung/wc_anlagen?format=image/jpeg&visibleLayers=WC-Anlagen,Gemeindegrenze,Pixelkarten%20und%20%C3%9Cbersichtsplan&searchtables=&startExtent=692000,241500,700100,249000&maxExtent=692000,241500,700100,249000
>             but I can't do it (In my tests only show name layer qgis
>             1.8 and name
>             layer and ).
>             Reading FeatureInfoDisplay.js file, comments say that
>             hoverPopup can
>             display the field named "toolbox" but I have tested to
>             create "toolbox"
>             field in my sample but in hoverPopup only layer name
>             appear (contents in
>             toolbox field are missing).
>             In this same file, the showFeatureInfoHover function use
>             'tooltip'
>             attribute and I tested again with a field named "tooltip"
>             in my data
>             sample but content not show.
>             Can somebody explain how to include data in hoverPopup?
>             _______________________________________________
>             Qgis-user mailing list
>             Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>             http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130912/884e3877/attachment.html>
