[Qgis-user] matplotlib is not found in QGIS 2.1.0-Master
William Kyngesburye woklist at kyngchaos.com
Sat Sep 14 08:03:52 PDT 2013
Doing anything in the Terminal won't help QGIS.  OS X applications do not get anything from the shell environment.  There is a section in the QGIS preferences to set environment variables.
FWIW, matplotlib is found for me with QGIS 2 on Lion.  And not found on Mt Lion, I'll see if I can figure this out.
On Sep 14, 2013, at 7:51 AM, Manuel Spínola wrote:
> Thank you very much Gene.
> How can I solve the problem?  I deleted the python 3.3 that I installed before.  Right now I have version 2.7.5., but still QGIS is asking me for the matplotlib.
> I don´t know much how to play with the Terminal.
> Best
> Manuel
> 2013/9/14 gene <martin.laloux at gmail.com>
> If you are a Python specialist, you can always try to add the site-package
> folder of one of the others Pythons (same version) to the PYTHONPATH of the
> Apple Python with sys.path.insert(0,'/usr/local/lib/python2.7'),
> site.addsitedir('/usr/local/lib/python2.7') or a .pth file, but beware of
> crashes....( Too many different Python versions on my system and causing
> problems
> <http://stackoverflow.com/questions/14117945/too-many-different-python-versions-on-my-system-and-causing-problems>
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
