[Qgis-user] Adding Projects to Qgis-Webclient - insertion into index.html seems not sufficient
Andreas Neumann a.neumann at carto.net
Sun Sep 15 07:58:22 PDT 2013
There seems to be an invalid composer in your project
(Druckzusammenstellung 4) with no map in the composer.
The javascript hangs because of this.
I recommend removing this "empty" print composer nr 4.
Of course we should also try to fix this in the javascript.
Can you try to fix the composer issue in your project?
As to the mapserver requests: these are in the GlobalOptions.js - search
for OverviewMap and replace it with a WMS that you want to use as the
overview map.
Hope this helps,
Andreas
Am 15.09.2013 12:17, schrieb Gunnar Oehmichen:
> Hey,
> right now I am trying to add our own projekts to the server (no virtual
> installation anymore), which again ends in "Map Loading". The
> helloword.qgs works fine. The test project "Test Amphibien Projekt -
> 4326" amphien_projekt_13.qgs is located within the /projects folders
> like its .shp layers. I checked the paths for <datasource></datasource>
> in .qgs file, they are also fine.
> http://gis.dienst.uni-landau.de/index.html
> This is our webclient
> System information:
> Ubuntu 12.04.2 LTS \n \l
> Server version: Apache/2.2.22 (Ubuntu)
> Server built:   Nov  8 2012 21:37:30
> Qgis Version: 1.8.0-1~precise4
> Qgis-Mapserver Version: Version: 1.8.0-1~precise4
> Web-Client (Could not get version information quickly):
> Last Updated: Monday December 10, 2012
> Last Change : Monday December 10, 2012 (from README)
> Paths in index.html, globaloptions.js, sites-available have been updated.
> Following javascript error happens when the "Test Amphibien Projekt -
> 4326" link is followed:
> Zeitstempel: 15.09.2013 13:55:24
> Fehler: TypeError: composerTemplate.map is undefined
> Quelldatei: http://gis.dienst.uni-landau.de/js/WebgisInit.js
> Zeile: 255
> While following the link to helloworld (which works fine) I get the
> these errors, allthough the map is loading.
> [Sun Sep 15 12:35:24 2013] [error] [client 95.116.227.18] script not
> found or unable to stat: /usr/qgis-web-client/cgi-bin/mapserv
> But no errors occured in the error-log when i tried to access the "Test
> Amphibien Projekt - 4326" (access log following). But one can see, that
> instead of 5 requests only 2 are beeing sent for the test projekt.
> Help would very much be appreciated, Thanks,
> Gunnar
> 95.116.227.18 - - [15/Sep/2013:12:34:33 +0200]
> "GET
> /qgiswebclient.html?map=/usr/qgis-web-client/projects/amphibien_projekt_2013.qgs&
>     format=image/png&visibleLayers=Area,Gewaesser,Orte,Verkehrsmonitoring,bufobufo,transekte
> HTTP/1.1"
>     200 1090 "-" "Mozilla/5.0 (X11; Ubuntu; Linux i686; rv:23.0)
> Gecko/20100101 Firefox/23.0"
> 95.116.227.18 - - [15/Sep/2013:12:34:35 +0200]
> "GET
> /cgi-bin/qgis_mapserv.fcgi?map=/usr/qgis-web-client/projects/amphibien_projekt_2013.qgs
>     &&_dc=1379241297287&SERVICE=WMS&VERSION=1.3&REQUEST=GetCapabilities
> HTTP/1.1" 200 1689 "-"
>     "Mozilla/5.0 (X11; Ubuntu; Linux i686; rv:23.0) Gecko/20100101
> Firefox/23.0"
> ### Get Map Request has not been sent for the Test-Projekt above.
> 95.116.227.18 - - [15/Sep/2013:12:35:23 +0200]
> "GET /qgiswebclient.html?map=/usr/qgis-web-client/projects/helloworld.qgs
>     &format=image/png&visibleLayers=Hello,Country HTTP/1.1" 304 212 "-"
> Firefox/23.0"
> 95.116.227.18 - - [15/Sep/2013:12:35:24 +0200]
> "GET
> /cgi-bin/qgis_mapserv.fcgi?map=/usr/qgis-web-client/projects/helloworld.qgs
>     &&_dc=1379241345761&SERVICE=WMS&VERSION=1.3&REQUEST=GetCapabilities
> HTTP/1.1" 200 1391 "-"
> Firefox/23.0"
> "GET
> /cgi-bin/mapserv?map=/path-to-map/.map&LAYERS=pk_kombiniert&FORMAT=image%2Fjpeg
>     &SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A4326
>     &BBOX=3.2332092650238,7.9247592650238,3.4117907349762,8.1033407349762&WIDTH=300&HEIGHT=300
> HTTP/1.1" 404 510 "-"
> Firefox/23.0"
> "GET
> HTTP/1.1" 404 511 "-"
> Firefox/23.0"
> "GET
>     &LAYERS=Country%2CHello&FORMAT=image%2Fpng&DPI=96&SERVICE=WMS&VERSION=1.1.1
>     &BBOX=-107.30402477621,-55.060559482089,113.94902477621,71.088659482089&WIDTH=1012&HEIGHT=577
> HTTP/1.1" 200 87735 "-"
> Firefox/23.0"
> Qgis-user mailing list
