[Qgis-user] Lost Sextante models
Jonas Sjögren jonas.sjo at gmail.com
Mon Sep 16 10:33:37 PDT 2013
Regarding the lost models, I found the following error message in History
and log, and the same goes for most of my models that do not show up:
Could not load model Calculate_FloodedObjects.model
Error in model definition line:Reclassified Grid Values : Traceback (most
recent call last):
File
"C:/PROGRA~2/QGISWE~1/apps/qgis-dev/./python/plugins\processing\modeler\ModelerAlgorithm.py",
line 164, in openModel
algParams[param.name] = AlgorithmAndParameter(int(tokens[0]), tokens[1])
ValueError: invalid literal for int() with base 10: 'Reclassified Grid
Values'
Anyone who has clue how to solve it?
Best regards,
Jonas
2013/9/16 Jonas Sjögren <jonas.sjo at gmail.com>
> Thank you for your instant reply. However, moving my models to
> "C:\Users\Username\.qgis2\processing\models" didn´t solve the problem, they
> still do not show up in the models folder in the toolbox. I have
> reinstalled Master 1.9.0-35, checked the pathways in options and
> configuration and rebooted my pc with no change. I have some scripts stored
> in "C:\Users\Username\.qgis2\processing\scripts" and they do show up,
> although not all of them. It seems as if the total number of them are
> stored somewhere else...? Regarding the models, I believe the file
> extension is the same as before, .model? The test models and example models
> are shown as usual, but where are these stored?
> Best regards,
> Jonas
> 2013/9/15 Werner Macho <werner.macho at gmail.com>
>> On 09/14/2013 09:24 PM, Jonas Sjögren wrote:
>> > I used to work in QGIS Master 1.9.0-4 where I have created some models
>> in
>> > Sextante. When upgrading to a more recent version, QGIS Master 1.9.0-35,
>> > they were suddenly lost. According to Sextante options and
>> configuration,
>> > the models are stored in C:\Users\Username\.qgis2\sextante\models, so I
>> > moved them there. But they still do not show up in the Sextante toolbox.
>> > Only Sextante example models and test models are shown. Is it possible
>> to
>> > import them in some way? I don´t really like the idea of rebuilding
>> > them...:-( If you have an idea, please let me know. Thanks,
>> Sextante has recently been renamed to "processing" so you should not put
>> your models into "C:\Users\Username\.qgis2\sextante\models" but rather
>> into "C:\Users\Username\.qgis2\processing\models" .. and get rid of that
>> whole "sextante" folder .. (or just rename it to processing)
>> That should do the job
>> kind regards
>> Werner
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130916/192495fa/attachment.html>
