[Qgis-user] trouble with processing-saga and libgdal
Goyo
goyodiaz at gmail.com
Tue Sep 17 08:09:53 PDT 2013
2013/9/17 matteo <matteo.ghetta at gmail.com>:
> Hi guys,
> I just added the ubuntugis repos (ubuntu 13.04) and install qgis and grass.
> Everthing is fine, but I cannot install saga.
> The problem is a conflict between the libgdal libraries:
> - with ubuntugis repos I have the libgdal1h installed
> - saga (both 2.0.8 and 2.1) requires libgdal1 (if I choose to install this
> version of libgdal I have to uninstall qgis and the other software that uses
> libgdal1h)
> Some trick to do that I miss?
You can try the development version of QGIS which depends on libgdal1.
You will have to downgrade some ubuntugis packages but I think it can
be done.
Goyo
