[Qgis-user] Mesaure tool Problem
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Sep 19 02:27:46 PDT 2013
hi,
so if you measure in QGIS desktop with project CRS set to 4326 you
measure 90m and in QWC with CRS 4326 you measure 130m for the same feature?
If I open a 4326-project in desktop my measure results are output in
degrees (can I change that somehow?), so I cannot compare to the QWC
output of the same project which is in metres. If you use a different
projection in desktop then your measurements may - of course - be different.
Measurement in QWC is handled using the OpenLayers' measure control [1]
Bernhard
[1]
http://dev.openlayers.org/releases/OpenLayers-2.13.1/doc/apidocs/files/OpenLayers/Control/Measure-js.html
Am 19.09.2013 10:50, schrieb Martin Baloga:
> Dear Bernard,
> e.g. by meauring length of cca 90 m in QGIS, the length measured in web
> client is approx. 130 m. The size of the are is approx. Twice the size. I
> guess maybe the units there are somewhere not properly set. But in
> options.js and webinit.js are only m.
> If you are interrested, i can send you wms link and address of the
> webclient. Thanx.
> S pozdravom / Best regards / Salutanta
> Ing. Arch. Martin Baloga, PhD.
> Pred vytlačením tohto e-mailu myslite na životné prostredie.
> Please consider your environmental responsibility before printing this
> e-mail.
> Mi petas vin pripensu pri via respondeco por la cxirkauxajxo antauxe elpreso
> de tiu-cxi mesagxo.
> __________ Information from ESET Mail Security, version of virus signature database 8817 (20130918) __________
__________ Information from ESET Mail Security, version of virus signature database 8818 (20130919) __________
The message was checked by ESET Mail Security.
http://www.eset.com
