[Qgis-user] Mesaure tool Problem
Martin Baloga matobaloga at gmail.com
Thu Sep 19 06:08:25 PDT 2013
Thank you, Bernard.
What about your portal of City of Jena, do you use GoogleMercator? Are your
distances measured in the geoportal right?
S pozdravom / Best regards / Salutanta
Ing. Arch. Martin Baloga, PhD.
www.jazzarchitecture.sk
+421 903 314 492
Pred vytlačením tohto e-mailu myslite na životné prostredie.
Please consider your environmental responsibility before printing this
e-mail.
Mi petas vin pripensu pri via respondeco por la cxirkauxajxo antauxe elpreso
de tiu-cxi mesagxo.
-----Original Message-----
From: Bernhard Ströbl [mailto:bernhard.stroebl at jena.de]
Sent: Thursday, September 19, 2013 2:52 PM
To: Martin Baloga
Cc: qgis-user at lists.osgeo.org
Subject: Re: Mesaure tool Problem
Hi Martin,
I further looked into this problem. As I indicated before the measure tool
is pure OpenLayers. Read the text underneath the example [1] for further
explanation (the map is somehow not working in the example).
Obviously QGIS desktop always uses "geodesic measures" whereas QWC never
does. I filed a ticket [2].
BTW the problem comes from the GoogleMercator projection as the Mercator
projection in general is known to only preserve angle while the area and
length errors increase towards the poles.
Bernhard
[1] http://www.openlayers.org/dev/examples/measure.html
[2] http://hub.qgis.org/issues/8630
Am 19.09.2013 12:00, schrieb Martin Baloga:
> Hi, Bernard,
> No, in desktop I have 900913 the project CRS, when I measure any
> feature, the result is 90 m. (The same as in ArcMap with S-JTSK CRS).
> When I open the project with CRS set to 900913, I got 130 m.  for the
> same feature. When I open the WMS in ArcMap or any other GIS viewer I got
again 90 m in 900913.
> The same, with the same values, happens when using 4326.
> Simply in QWC for some reason the measure is different. I would realy
> appreciate if the measures are correct. I am prepraring QWC for a
> municipality and the difference between parcel area in attribute and
> measure tool is quite confusing...
> S pozdravom / Best regards / Salutanta Ing. Arch. Martin Baloga, PhD.
> +421 903 314 492
> e-mail.
elpreso
> de tiu-cxi mesagxo.
> Sent: Thursday, September 19, 2013 11:28 AM
> To: qgis-user at lists.osgeo.org
> Cc: Martin Baloga
> hi,
> so if you measure in QGIS desktop with project CRS set to 4326 you measure
> 90m and in QWC with CRS 4326 you measure 130m for the same feature?
> If I open a 4326-project in desktop my measure results are output in
degrees
> (can I change that somehow?), so I cannot compare to the QWC output of the
> same project which is in metres. If you use a different projection in
> desktop then your measurements may - of course - be different.
> Measurement in QWC is handled using the OpenLayers' measure control [1]
> Bernhard
> [1]
http://dev.openlayers.org/releases/OpenLayers-2.13.1/doc/apidocs/files/OpenL
> ayers/Control/Measure-js.html
> Am 19.09.2013 10:50, schrieb Martin Baloga:
>> Dear Bernard,
>> e.g. by meauring length of cca 90 m in QGIS, the length measured in
>> web client is approx. 130 m. The size of the are is approx. Twice the
>> size. I guess maybe the units there are somewhere not properly set.
>> But in options.js and webinit.js are only m.
>> If you are interrested, i can send you wms link and address of the
>> webclient. Thanx.
>> e-mail.
>> elpreso de tiu-cxi mesagxo.
>> __________ Information from ESET Mail Security, version of virus
>> signature database 8817 (20130918) __________
> __________ Information from ESET Mail Security, version of virus signature
> database 8818 (20130919) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
http://www.eset.com
