[Qgis-user] How set the SVG path in qgis-server
aperi2007 aperi2007 at gmail.com
Thu Sep 19 15:12:16 PDT 2013
thx for this hint.
I try this option but it seem don't work.
This is what I do:
I copy all my svg symbols in a subfolder "folder1/folder2" of the
"/usr/local/share/qgis/svg" path
(so they are all located in this path:
/usr/local/share/qgis/svg/folder1/folder2)
And after this,
I do a search and replace on the qgis project to change all the svg
symbols path from something like this
<prop k="name" v="/Frane/1000-a.svg"/>
To something like this
<prop k="name" v="/folder1/folder2/Frane/1000-a.svg"/>
I test the wms map but the svg symbols are not used.
Maybe the v parameter cannot have a subfolder path ?
Thx,
Andrea.
On 19/09/2013 23:53, Andreas Neumann wrote:
> Hi,
> Not that I know of - but you can put your SVG symbols into wherever
> QGIS has its builtin SVG symbols, e.g. /usr/local/share/qgis/svg
> Symbols relative to the project file should also work.
> Andreas
> On Thu, 19 Sep 2013 23:17:31 +0200, Andrea Peri wrote:
>> Hi,
>> Is possible to set an extra path for SVG symbols (as in qgis desktop)
>> for qgis-server ?
>> Thxs
> Qgis-user mailing list
