[Qgis-user] Intersect Performance
G. Allegri
giohappy at gmail.com
Sun Sep 22 11:45:08 PDT 2013
Keep in mind that with GRASS you need your data to be topologically quite
clean, because it treat them topologically.
QGIS's internal overlay processing isn't very optimized...
Sent from Nexus
Il giorno 22/set/2013 18:53, "António M. Rodrigues" <
amcrgrodrigues at gmail.com> ha scritto:
> Hi,
> As expected, GRASS 7 out-performs all the others. Nowdays, when working
> with large datasets, I rather use PostGIS. Fast, robust. With GRASS 7 you
> can easily talk to your postgres databases which is a great help.
> You could try GRASS from QGIS but as far as I know, qgis doens't peak to
> grass7.
> Cheers,
> António
> 2013/9/18 bjorn.burr.nyberg at gmail.com <bjorn.burr.nyberg at gmail.com>
>> Any suggestion on this? Reason I ask is that its quite a fundamental step
>> in
>> my scripts.
>> see
>> http://gis.stackexchange.com/questions/71632/grass-v-overlay-qgis-intersect-speed-intersecting-line-and-polygon
>> Cheers
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Intersect-Performance-tp5077130p5078413.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130922/e0113022/attachment.html>
